2
OnePlus One stuck in Bootloop!!
  1. jenish112
    Gingerbread Oct 29, 2017
    jenish112 , Oct 29, 2017 :
    I don't know exactly what you mean by that. But it was working fine since 7-8 days than suddenly this happened.
  2. Copperstone77
    Froyo Oct 29, 2017
    Copperstone77 , Oct 29, 2017 :
    The OnePlus 5 uses an encrypted storage and ROMs released are specifically for this. There are however certain ROMs that need a decrypted storage (decrypted ROMs, I think LineageOS).
    But I guess you're not having this issue.
  3. Copperstone77
    Froyo Oct 29, 2017
    If clearing cache or dalvik cache didn't work then try the following.
    If you can access recovery and fastboot, then head to your Recovery, and wipe data/factory reset. This won't erase your internal storage (images, music, videos, e-books etc), but your SMSs will definitely be gone. As for your call logs, WiFi passwords, other passwords; they'll get restored once you sign back in to Google. Hope it works!
  4. Copperstone77
    Froyo Oct 29, 2017
    This is absolutely wrong. Battery has nothing to do with bootloop issues. Also custom ROMs give more stability, flexibility, scalability, all other "-lities" than OEM ROMs.
    elanglois and jenish112 like this.
  5. jenish112
    After factory resetting the phone booted up but restoring nandroid backup again leads to bootloop.
  6. jenish112
    Yeah seems like that's the only option left.
  7. elanglois
    Lollipop Oct 29, 2017
    elanglois , Oct 29, 2017 :
    Lineage should work with encryption on. Most should. I keep it on with my 3T and was swapping ROMs frequently without issues.
  8. elanglois
    you'll have to install your apps via play store then, but it shows the issue is corrupt data
    jenish112 likes this.
  9. Copperstone77
    Froyo Oct 29, 2017
    Yeah LineageOS and it's derivatives like RR and others do use encrypted format, and works on the device by default.
  10. jenish112
    Did the same. So far so good. Hope it stays that way.
    Just to know is there any specific reason for such sudden corruption of data?
  11. elanglois
    Yes.
    Bad Luck
  12. Nagkamal_varma
    Donut Oct 29, 2017
  13. TheMystic
    TheMystic , Oct 29, 2017 :
    do this.
    take a nandroid backup.
    wipe all your partitions (except internal storage) and do a clean install of the previous RR build.
    if you are now able to boot, you can backup all your files the normal way.
    if not, you will have to backup via ADB.
    Note: You will lose your apps and app data with this procedure.
  14. TheMystic
    are you sure about what you are saying here?
    my device is encrypted. I have flashed various ROMs without any problems.
    I think that specific requirement of decrypted storage only needed for MultiRom.
  15. Copperstone77
    Froyo Oct 29, 2017
    No, I made a mistake. Most of the ROMs including LineageOS and its derivatives require encrypted storage. That is the default.
  16. jenish112
  17. jenish112
    Tried that. By factory resetting or making a clean install would boot the device but as soon as I would restore the data problem would start again. As @elanglois said some data might be corrupted which caused the problem.
  18. Copperstone77
    Froyo Oct 29, 2017
    Did you have a pin or lockscreen password before taking a backup? If so, that backup has gone to waste. You need to remove your pin or password temporarily before taking a Nandroid backup.
    #38
  19. elanglois
    I don't believe this is true.
    #39
  20. jenish112
    Gingerbread Oct 30, 2017
    jenish112 , Oct 30, 2017 :
    Yes I did have a lockscreen password. But its hard to believe that it would have any effect on Nandroid backup.
    #40
