11
Oneplus One Wireless Charging Hack(2nd Method)
  1. FROZen
    Gingerbread Jul 7, 2014
    FROZen , Jul 7, 2014 :
    NOTICE: THIS METHOD INVOLVES TAKING APART YOUR BELOVED ONE+ ONE. IF YOU ARE NOT COMFORTABLE TAKING APART YOUR PHONE, THEN USE THE 1ST METHOD
    ---------------------your warranty is now void--------------------------
    Sup guys, I'm back with another awesome thing for you. As mentioned above you will have to take apart the phone.. well not fully, we need to reveal the charging port remove the battery.
    I haven't done this method but im pretty sure it will work. Have a look at the images below
    I have labeled some parts, as you can see the battery is removed and the micro usb port is showing. now what you need is the wireless charging mat (the black part represents it ).
    Click Here to buy it.
    cut the end of the mat and separate the wires. The most important ones are the black and white.
    No for this part I'm not fully sure but temporally attach the black wire to the the pin on the left and white one to the right. put the battery back in and put the wireless mat on a wireless charger. If it charges then use soldering iron to attach the wires to the pins. If it doesn't work then use diffent configurations. when you find the working one, solder it to place.place the mat on the top of the battery and glue it there. Put the case back and you are good to go.
    YOUR ONE+ ONE UNOFFICIALLY SUPPORTS WIRELESS CHARGING. ENJOY
    Edit:
    Someone did this with the one
    http://imgur.com/a/jRnN4
  2. FROZen
    BTW I DON'T RECOMMEND, UNLESS YOU HAVE INSURANCE, AND HAVE KNOWLEDGE ABOUT SOLDERING AND ELECTRICAL EQUIPMENT
    Yagami Raito and Reflect Stratos like this.
  3. RogueS4
    Jelly Bean Moderator Jul 7, 2014
    Elisha Siegelman likes this.
  4. Grahl
    Honeycomb Jul 7, 2014
  5. FROZen
    why? this post is regarding the one+ one
  6. FROZen
  7. eibook
    Donut Jul 7, 2014
    eibook , Jul 7, 2014 :
    What's the difference? If you have a yellow screen they won't replace, you may as well add another feature and resell the phone.
  8. FROZen
    If you live in the EU, they WILL have to replace/refund/repair the device if the devices arrives faulty..
    knoxy1 and lutti like this.
  9. Grahl
    Grahl , Jul 7, 2014 :
    you have a point
  10. Nasrumed
    Grahl likes this.
  11. RogueS4
    RogueS4 , Jul 7, 2014 :
    The "One" subforum should be used to talk about the one itlself. This post is about a piece of technology that allows you to add wireless charging to the one. With that said your post fits better into the tech talk
  12. eibook
    Donut Jul 7, 2014
    Who is to say it's faulty?
    Look at some of the threads around here...
  13. FROZen
    I think you should get a replacement if you feel like its faulty..
  14. andr1171
  15. eibook
    Donut Jul 7, 2014
    I would tend to agree but maybe OP does not agree.
  16. bojer
    bojer , Jul 7, 2014 :
    You don't say ONE important thing. First you need own OPO phone :)
  17. FROZen
    not if you know about these stuff.. or bring this device to your local phone repait shop and ask them to do it for you.. its a piece of cake for them
  18. derin38
    Froyo Jul 7, 2014
    derin38 , Jul 7, 2014 :
    EU might agree though.
  19. FROZen
  20. FROZen
    If you have that problem, then your are not the only person to have it, atleast 5% of opo devices are affected.. its a fault.
