11
Oneplus One Wireless Charging Hack(2nd Method)
  1. gagan
    Honeycomb Jul 7, 2014
  2. Waterdroid
    Community Veteran Jul 7, 2014
    Waterdroid , Jul 7, 2014 :
    Moved to Accesories. Seems a tad more appropriate if you don't mind. :)
    RogueS4 likes this.
  3. RogueS4
    Jelly Bean Jul 7, 2014
    RogueS4 , Jul 7, 2014 :
    Nope :)
    Waterdroid likes this.
  4. FROZen
    Gingerbread Jul 7, 2014
    FROZen , Jul 7, 2014 :
    can you guys keep moving the post.. more people will see it :D
    gusuraman and Waterdroid like this.
  5. Gslide
    Gslide , Jul 7, 2014 :
    Is there software to support this or is it all built into the mat?
  6. FROZen
    everything is built into mat, no need for root or flashing
  7. rickneworleansla
    Ice Cream Sandwich Jul 7, 2014
  8. rickneworleansla
    rickneworleansla , Jul 7, 2014 :
    Nevermind. I guess it probably matter anyway if you are going to cut it open to expose the wires.?
  9. FROZen
    Down. we ordered both variations as we were not sure, you will have to twist the up one
  10. FROZen
    it will actually, even if you cut it , the wires are flipped so the red will be black and vice versa.
    rickneworleansla likes this.
  11. rickneworleansla
    Got it, thanks.
  12. Peanutbrain
  13. Index
    Gingerbread Jul 8, 2014
    Index , Jul 8, 2014 :
    Now I know what to do as soon as I get an invite.... Buy a Soldering Iron!!!!
  14. rdubbs007
    Donut Jul 10, 2014
    rdubbs007 , Jul 10, 2014 :
    Please respond with pics of actual mod and if it actually works well or not... obviously in theory it should work and I have been thinking about this for a couple of days now. Also a link to the charging mat from amazon would be helpful for people that are unsure which one to get, I would assume this is suitable:
    http://amzn.com/B00JIN22JM
    To continue with a possible alternative, if you remove the top portion under the cover and expose the flex cable connectors to the logic board, I am curious if there may be pads located there connected to the traces for the vcc and gnd wires to be more easily soldered to. Will have to test out with a multimeter whenever I get around to it I suppose.
  15. FROZen
    Gingerbread Jul 10, 2014
    FROZen , Jul 10, 2014 :
    Yes, that would be perfect, My friend, as of now is not gonna do this But if i get an invite i will definitely do this
  16. jase33
    Jelly Bean Jul 10, 2014
  17. Assim
    Cupcake Jul 10, 2014
    Assim , Jul 10, 2014 :
    I need an invite. 16GB or 64GB Plz Invite Me .... I need a new phone....
  18. Lavenchi
    Donut Jul 11, 2014
    Lavenchi , Jul 11, 2014 :
    To be honest super risky to do and i'm not sure most insurances cover intentional tampering
    #38
  19. gmo8492
    Lollipop Jul 11, 2014
    #39
  20. kera
    Gingerbread Jul 11, 2014
    kera , Jul 11, 2014 :
    Which insurance company would cover self-inflicted damage? Unless you're prepared to lie and say that your phone was stolen or something, and they actually cover theft?!
    I'm quite certain that this is not how it works. Just because you "feel" like it's faulty, doesn't mean OP agrees that it is. :)
    #40
