141
OnePlus Pinoy Fan Club
When we can avail this phone in the Philippines?
Poll closed Dec 25, 2014.
  1. December 2014?
    24.0%
  2. Year 2015?
    54.5%
  3. Not at All
    29.3%
Multiple votes are allowed.
  1. kyroblue
    Froyo May 6, 2015
    kyroblue , May 6, 2015 :
    Yup.. Good morning.. Ang layo pa pla ng 60k.
    Happy Lunch sa inyo!
    Mjo, jehhact, ariestotel and 3 others like this.
  2. fo0ling
    KitKat May 6, 2015
    Mjo, jehhact, Tedge and 1 other person like this.
  3. fo0ling
    KitKat May 6, 2015
    Mjo, jehhact, GhilS and 4 others like this.
  4. kyroblue
    Froyo May 6, 2015
    Mjo, jehhact, GhilS and 3 others like this.
  5. fgaurano
    Ice Cream Sandwich May 6, 2015
    fgaurano , May 6, 2015 :
    Ipamimigay niyo po previous cases? Thank you po. :p
    Hmm. Titingnan ko Glove APN settings ng mama ko.
    Prepaid po ba or postpaid? If postpaid po:
    APN: internet.globe.com.ph
    Proxy: Not set
    Port: Not set
    Username: Not set
    Password: Not set
    Server: Not set
    MMSC: Not set
    MMS Proxy: Not set
    MMS Port: Not set
    MCC: 515
    MNC: 02
    Authentication Type: PAP
    APN type: default, supl
    APN protocol: IPv4
    APN roaming protocol: IPv4
    Enable/disable APN: APN enabled
    Bearer: Unspecified
    Hindi ko po alam kung bakit naka lock yung MCC at MNC niyo po, try nalang po contact CS.
    Mjo, jehhact, ariestotel and 2 others like this.
  6. kyroblue
    Froyo May 6, 2015
    @GhilS i need u po.. May HO po kau?
    Lam na..ung diztronic dati na yan.. Ung flip bago
    Mjo, jehhact, fgaurano and 3 others like this.
  7. hotland
    Gingerbread May 6, 2015
    jphi422, Mjo, jehhact and 2 others like this.
  8. hotland
    hotland , May 6, 2015 :
    hayaan mo na as is un. mnc 02 yan kasi by sequence ata yan sa ibng apn na nka save sayo pero ang basic lang nmn tlg sa apn ung apn nya at ung server ip port proxy
    Mjo, jehhact, fgaurano and 1 other person like this.
  9. hotland
    paano ba mag request? wala ba silang form? or google docs?
    Mjo, jehhact, fgaurano and 2 others like this.
  10. fo0ling
    KitKat May 6, 2015
    fo0ling , May 6, 2015 :
    ung pagkuha ng tshirt? you will need to do a tedious task. its not that easy.
  11. jzmoreno
    Eclair May 6, 2015
    jzmoreno , May 6, 2015 :
    Anybody know why this happens when i switch from Oxygen to COS12?
    On Oxygen:
    On COS12 (also there is a persistent "R" on signal bars, even if roaming and mobile data is OFF)
    tia :)
    Mjo, jehhact and fgaurano like this.
  12. crixx
    Cupcake May 6, 2015
  13. Tedge
    Honeycomb May 6, 2015
    ariestotel, JopeTski, Mjo and 2 others like this.
  14. fgaurano
    Thank you po in advance sa case. :D :p
    ariestotel, JopeTski, Tedge and 3 others like this.
  15. jehhact
    Froyo May 6, 2015
    ariestotel, JopeTski, Tedge and 4 others like this.
  16. kyroblue
    Froyo May 6, 2015
    Lam na.. Nawawala ka nmn bigla..
    jehhact, ariestotel, JopeTski and 4 others like this.
  17. kyroblue
    Froyo May 6, 2015
    jehhact, JopeTski, Tedge and 2 others like this.
  18. GhilS
    jehhact, ariestotel, JopeTski and 3 others like this.
  19. GhilS
  20. kyroblue
    Froyo May 6, 2015
    Wow... Ang mura nmn... Bilhin kona?
