2
OnePlus Power Bank
  1. Hashir456
    Donut Oct 20, 2020
    Hashir456 , Oct 20, 2020 :
    Hey everyone,
    Wanted to check something regarding the recently launched OnePlus Power bank. Although The description says that it supports 18W fast charge, my OnePlus 7t is not charging fast when plugged it into the power bank.
    Let me know if I'm using it correctly or any other way to troubleshoot this issue.
    Thanks
    Aryank988 and L1570873333488 like this.
  2. L1570873333488
    Cupcake Oct 22, 2020
    Aryank988 likes this.
  3. Syedjameel7060
  4. Tokolozi
    Nougat Oct 22, 2020
    Tokolozi , Oct 22, 2020 :
    It supports 18W fast charge in all device normally.
  5. GuitarBart
    Jelly Bean Oct 22, 2020
    GuitarBart , Oct 22, 2020 :
    There was another thread on this that I can't find at the moment. There are a couple 18w charging standards so it seems to be a bit tricky
  6. Last edited: Oct 26, 2020
  7. Sridhar Ananthanarayanan
    Lollipop Oct 23, 2020
    Sridhar Ananthanarayanan , Oct 23, 2020 :
    It is not just the power bank/ charger, your cable should also support it. Cables too come with power capacity and data transfer speeds. So check that too.
  8. Hashir456
    Donut Oct 23, 2020
    Hashir456 , Oct 23, 2020 :
    I mean yeah, the 18W fast charge claim is a little misleading
  9. Hashir456
    Donut Oct 23, 2020
    I tried using the warp charger cable only. No luck with it on the power bank
  10. Hashir456
    Donut Oct 23, 2020
    if im not mistaken you're talking about the USB cable right?
  11. Sridhar Ananthanarayanan
    Yes. The cable that you used to charge the phone with the power bank. How long does it take to charge the phone fully from 15%?
  12. Hashir456
    Donut Oct 23, 2020
    I've charged it fully starting from 40% actually. And this is using the longer warp charger cable. Took around 1.5 hours to full charge.
  13. knightkiller
    Cupcake Oct 24, 2020
    knightkiller , via OnePlus 6T , Oct 24, 2020 :
    It doesn't answer the real question here as we know there is lot of different types of charging warp, dash, vooc, super vooc, out of which none support other our only question is does this power bank support dash or warp charging if not however this is not good for OnePlus cause if the charger is not of dash or warp the default would be 5v 2a which is total of 10 watt but however why did we wait for OnePlus powerbank where we could buy some other brand right?
    Aryank988 and Hashir456 like this.
