1226
OnePlus Software Maintenance Schedule
  1. ASCHENTE_V
    KitKat Jul 27, 2018
    ASCHENTE_V , Jul 27, 2018 :
    sumonuap
    you should learn the difference between beg and deserve. google it.
    I should nothing, especially to you. Go and buy another smartphone if you want project treble or keep begging 1+ for it. You, little kid, paid for the smartphone, not for the software updates, so say thanks for 8.0 and possible 8.1. Also I said abour 5 years of support for xiaomi flagship smartphones, not for the middle price and I did't say ANYTHING about project treble. You don't deserve it, you just beg it
    Vladut123 and H1527776620308 like this.
  2. G_Himanshu_Rai_dGbU
    Gingerbread Jul 27, 2018
    G_Himanshu_Rai_dGbU , Jul 27, 2018 :
    what that mean does OnePlus 3/3t will get 8.1 soon.
    (We look forward to bring you more exciting news about Android version updates for OnePlus 3/3T in the coming months, stay tuned)
    Vladut123 likes this.
  3. patrice58
    Ice Cream Sandwich Jul 27, 2018
    patrice58 , Jul 27, 2018 :
    Really even though Pixel phones are guaranteed 3 years of Android updates?
  4. patrice58
    They will probably update it in November 2018.
  5. dsmonteiro
    Community Consultant Staff Member Jul 27, 2018
    dsmonteiro , Jul 27, 2018 :
    No, they aren't. They are guaranteed the same OnePlus is now offering, and it's far from a industry standard. Most brands don't do it.
    Vladut123 and superplus like this.
  6. sumonuap
    sumonuap , Jul 27, 2018 :
    first time i didn't even mention the other updates. i just told about project treble.
    and i bought oneplus for software and updates. if i didn't need the update then i could buy the other phone with that money.
    [abusive comment removed by moderator]
  7. sumonuap
    hey, big bug,
    if you don't need updates then you should use other smartphones moneyboy.
  8. dsmonteiro
    Why exactly do you "deserve" Treble? Would love to hear the logic behind that.
    Did OnePlus promised it to you?
    Is OnePlus is any way obligated to provide Treble support?
    Did you actually pay for it?
    Seeing that the answer to all those questions is "No." I fail to see the logic. Especially considering that Treble isn't something that will impact you directly in any way.
  9. superplus
    Head Moderator Head Moderator Jul 27, 2018
  10. Andyynwa
    Cupcake Jul 27, 2018
    Andyynwa , Jul 27, 2018 :
    Hi I have a problem with my oneplus6 cannot adjust my ring calls volume.From button and also slider
  11. superplus
    superplus , Jul 27, 2018 :
    Hi, welcome to the forums, please have a look at the Terms & Rules (https://forums.oneplus.com/help/terms) and note that your comment differs from the overall thread topic.
    In general, if you have any issues it is useful if you provide details, such as the device you are using, your current OS version, if this has always been an issue, or only since a recent update, if it only occurs in some position of the alert slider or if is an issue in all alert slider positions.
    For instance, if the alert slider is in the top position, the device is set to "silent", so you should indeed not be able to adjust the volume. If, however, you are in the bottom position, which should allow all notifications, and you are not able to adjust it, neither using the volume buttons, nor in the settings menu, then you might be facing some device issue.
    Please feel free to send me a PM with any further details: https://forums.oneplus.com/conversations/add?to=superplus
  12. Andyynwa
  13. patrice58
    Vladut123 and dsmonteiro like this.
  14. dsmonteiro
    Community Consultant Staff Member Jul 28, 2018
    dsmonteiro , Jul 28, 2018 :
    I stand corrected. They changed their update policy with the Pixel 2 but I was unaware. It used to be 2+1, but now it's 3+3, according to that article. Sweet!
    Still, a long term commitment on software updates is something that makes me more confident.
    The only things I still prefer on Pixel devices is how fast the updates are made available and the camera.
    Vladut123 and patrice58 like this.
  15. Aziz_Amin_Oneplus
    Jelly Bean Jul 28, 2018
    Aziz_Amin_Oneplus , Jul 28, 2018 :
    I also hope OnePlus will keep their promise retain in the future so we fans can keep ourself happy and not worried all about in the end.
  16. patrice58
    Ice Cream Sandwich Jul 28, 2018
    patrice58 , Jul 28, 2018 :
    Definitely and remember OnePlus users are not paying as much as it would cost for a Pixel. (Not far off as One Plus are getting increasingly greedy but it's not there yet.)
  17. Y1527706398614
    Cupcake Jul 28, 2018
    Y1527706398614 , Jul 28, 2018 :
    my lock pattern is not coming when I swip up ...I directly go to the home screen ... u checked the settings its fine .....what is the problem?
  18. gautham06
    Cupcake Jul 29, 2018
    gautham06 , Jul 29, 2018 :
    iPhone 5s got 5 years of software support ! I wanted something like that from OnePlus too ! [e]2764[/e]️
  19. Aziz_Amin_Oneplus
    Jelly Bean Jul 29, 2018
    Aziz_Amin_Oneplus , Jul 29, 2018 :
    iPhones have other policies which cannot be same as like Android's ones as Android phones are very much common unlike the iPhones, they are less so they can benefit otherwise they wouldn't.
  20. 2020amolg
    Honeycomb Jul 30, 2018
    Vladut123 and Artemus. like this.
