OnePlus Travel Backpack, water resistance
  1. RonaldM
    Ice Cream Sandwich Jan 22, 2017
    RonaldM , Jan 22, 2017 :
    I have a question about the OnePlus Travel Backpack. I would like to by it but I want to use it for my daily commute to the office on my bike. Living in the Netherlands rain can be expected in different forms. So I am curious to know whether the backpack is water resistant, so I can bring my laptop and other stuff with me safely.
    I would like to hear from the OnePlus Travel Backpack owners how their experience is so far.
    Bart1999 likes this.
  2. larseisberg
    Honeycomb Jan 22, 2017
    larseisberg , Jan 22, 2017 :
    I have used mine everyday since getting it when it was launched, and while I wouldn't directly say it`s water resistent, because I think it doesn't say so on the OnePlus website, I have been wearing it while it was raining and never experienced any humidity/water leaking through on the inside. The outside color does however change a little bit when in contact with water so it can look like it is a little bit dirty, but that is to be expected considering it's light color. The interior also looks like it should be able to resist water, so it's not just a flimsy fabric, but more of the material that you can find in raincoats. I can imagine though that if exposed for multiple hours to heavy rain, there might be a chance of some humidity/water getting inside the backpack.
    Bart1999 and RonaldM like this.
  3. NumLox
    Donut Jan 23, 2017
  4. whitekelvin
    Cupcake Feb 9, 2017
    whitekelvin , Feb 9, 2017 :
    I recently purchased the backpack from Archer Brighton as one of my friend suggested me to buy from here. I like it because it is is water and stain resistant. You can also try this one
  5. Bart1999
    Honeycomb Jun 29, 2017
    Bart1999 , Jun 29, 2017 :
    Does one of you guys know if my 15.6 inch laptop will fit this backpack? On the website it isn't clear!
  6. larseisberg
    Honeycomb Jun 30, 2017
    larseisberg , Jun 30, 2017 :
    I really don't know about my backpack (the lunar grey old model), but the new travel backpacks that were announced with the OP5 can fit up to 15" and have an extra zipper for your laptop as well. Definitely would recommend going for the new one. I think the fit is going to depend on your laptops size though ( like bezels etc.).
  7. amit11289
    Eclair Jun 30, 2017
  8. Bart1999
    Bart1999 , Jun 30, 2017 :
    Thanks but my question is can it fit laptops up to 15 inch or up to 15,9 inch?!
    When up to 15 inch my 15,6 inch laptop won't fit
  9. larseisberg
    The website says 15 inches, but it shows a 15,4" MacBook next to it, so I guess it must fit more. Again, that depends on the screen bezels of your notebook. You could also go ahead and ask support for the concrete numbers.
  10. Bart1999
    Thanks for your reply!
  11. Tairon
    Cupcake Dec 15, 2017
    Tairon , Dec 15, 2017 :
    I've recently bought the Luna Dust version, although i was not totally sure it would fit my laptop. I would like to leave a confirmation here, that it is perfect for my 15.6 inch laptop. I use it daily with a Lenovo Y520 and it is very convenient.
    The dimensions of the laptop:
    WxDxH: 14.96" x 10.43" x 1.01" (380mm x 265mm x 25.8mm)
    You could fit a bit bigger, but not too much.
    I've had a great experience with the bag, i would recommend it gladly to anyone.
  12. Bart1999
    Honeycomb Dec 17, 2017
    Bart1999 , Dec 17, 2017 :
    Two months ago I purchased the black space backpack. The backpack is so awesome. No complaints yet. And. My 15,6 inch laptop fits just in the backpack.
