2
Oneplus TV U1 loud static Noise & shutdown issue
  1. ronakk93
    Cupcake Aug 3, 2020
    ronakk93 , Aug 3, 2020 :
    I have been facing with my recently purchased Oneplus TV U1.
    It suddenly gives out a loud static noise and then shut downs.
    I dont know does it happen when i am using just Netflix but it is happening 2-3 times a day.
    Checked the plug socket if the problem was with a loose fit plug, but it looks good.
    Pls help me with it. Also saw the same problem on amazon reviews from another user.
    Q1586876078825 and parthpatel643 like this.
  2. Venky61
    OnePlus TV Expert Community Expert Aug 4, 2020
    Venky61 , Aug 4, 2020 :
    Hi,
    I would suggest reaching out Customer Care and raise a ticket, so that a technician would visit and check it. That way you are not to blame if the whole device fails later.
    Amanrae likes this.
  3. ManoGeeks
    Eclair Aug 9, 2020
    ManoGeeks , Aug 9, 2020 :
    I received my new One Plus 55 U1 series TV today. At first start the TV turned on fine I've set it up with all the steps till home screen. Tested all the sound and display, it went fine for like 30 mins, the TV was on as it was i stepped out for an hour and come back home. The TV got turned off automatically, then i tried to on it back. It shows up till One Plus Logo makes weird sound and turns off. I'm really sad with this purchase. Not even 3 hours the TV IS DEAD. Really dissatisfied.
  4. ManoGeeks
    Eclair Aug 9, 2020
  5. ManoGeeks
    Eclair Aug 9, 2020
  6. Venky61
    OnePlus TV Expert Community Expert Aug 10, 2020
    Venky61 , Aug 10, 2020 :
    Hey.. That's really bad.
    Contact Amazon CS for a replacement asap.
  7. ManoGeeks
    Eclair Aug 10, 2020
    ManoGeeks , Aug 10, 2020 :
    Yes Venky, even i was shocked too, i think One Plus needs to test their units thoroughly before delivering it to their customers.
    Here's again multiple attempts, this is how it shows up
    https://drive.google.com/file/d/1ETuBjpmNq2t2UrBpsJ_HuJ4MbUsqgZ18/view?usp=sharing
    https://drive.google.com/file/d/1KkqD4RE768H6l5mQ3CddswVvXNFNRpao/view?usp=sharing
    I've contacted Amazon CS, Appointment has been scheduled for inspection, hopefully Amazon will replace it.
    Aarav Sahni and Venky61 like this.
  8. ManoGeeks
    Eclair Aug 10, 2020
    Update as of now, it doesn't even boot till home screen. Seems like One Plus sent me a defective piece. Not good.
  9. ManoGeeks
    Eclair Aug 10, 2020
    How long it's been you purchased this device ? Is it the same problem existing for you too as i shared above ?
  10. ronakk93
    Cupcake Aug 10, 2020
    ronakk93 , Aug 10, 2020 :
    No my TV works fine on normal dish tv. But when i switch to OTT apps in Built on oxygen play, it crashes badly. But still it works
  11. ManoGeeks
    Eclair Aug 10, 2020
    I'm really confused what's going on with One Plus TV, they need to fix this issues before the damage is done to this product. I strongly believe the new update is causing lot of issues. Many users complaining on OTT apps while watching, it suddenly shuts off !
  12. ManoGeeks
    Eclair Aug 12, 2020
    ManoGeeks , Aug 12, 2020 :
    I'm really exhausted keeping calling to Amazon and One Plus Customer Care. No proper support has been assigned to look over this issue by any of them. Not Fair.
  13. ManoGeeks
    Eclair Aug 12, 2020
  14. Rick Y.
    OnePlus TV Software Engineer Staff Member Aug 14, 2020
    Rick Y. , Aug 14, 2020 :
    Hi, ManoGeeks,
    Sorry for the bad experience, has this problem been solved?
    Is the TV connected to other devices (such as amplifiers)? If these devices are unplugged, does the TV work normally?
  15. ManoGeeks
    Eclair Aug 14, 2020
    ManoGeeks , Aug 14, 2020 :
    Hi Rick,
    Not yet, the problem is still hanging on. No external devices are connected to the TV.
    See the detailed video how the TV shuts off all of the sudden. After this the TV wont even power up again, i need to wait for a day to boot up as now, but it repeats the same.
    https://drive.google.com/file/d/1Hbl18ySIdUEgERXiY0Y2FYY3_r_fNyJT/view?usp=sharing
    This is happening from the day one of the purchase.One Plus Care team has not taken this issue seriously, i have been requesting for support but sadly no one showed up. I'm still wondering would i really get help for this ?
    This been a really bad experience for me. Didn't expect this from One Plus.
  16. Rick Y.
    Thank you for your feedback. It has been reported to the after-sales team, please be patient.
    Before that, please do a TV factory reset to see if the issue can be solved, thanks!
  17. ManoGeeks
    Eclair Aug 14, 2020
    I appreciate your help Rick. Factory reset ? how that can be done, if you can explain me how do it, i will give a try.
  18. Rick Y.
    Please follow the steps: Settings > More Settings > Reset > Reset > Erase everything.
  19. ManoGeeks
    Eclair Aug 14, 2020
    If it permits till there, i will give try. If not the TV needs hands on for sure to look into the issue.
  20. ManoGeeks
    Eclair Aug 15, 2020
