23
Guide OnePlus Two bootloader unlocker, rooter and recovery flasher AIO
  1. waicool20
    Gingerbread Aug 9, 2015
    waicool20 , Aug 9, 2015 :
    Have fun:
    https://drive.google.com/file/d/0B_sgF3n4MJzKTmd1WUVjNFR2OTQ/view?usp=sharing
    Oxygen OS 2.0 ROM over here: http://1drv.ms/1K2uYvp
    Happy waiting international users..... :) No invites either :p
    Not my work, I just translated it from here:
    http://www.oneplusbbs.com/thread-846120-1-1.html
    Instructions:
    Updates:
    When flashing O2 with this, remember to do a full wipe and don't turn on dark mode! It will cause apps to spontaneously crash and instability. Be aware!
    #FAQ
    Does rooting, unlocking bootloader void my OP2 warranty?
    No.
    The technical process of rooting or unlocking the bootloader does not void the warranty of the OnePlus One. However, we strongly suggest for you to only root or unlock the bootloader of the OnePlus One if you are confident that you understand the risks involved.
    By accessing resources regularly unavailable to software, the process may damage your hardware during or after the procedure, which is not covered under warranty. In warranty handling, we will need to verify that any faulty behavior is unrelated to rooting / unlocking first.
    Disclaimer: ONLY FOR THE OP2, DON'T ATTEMPT TO USE THESE TOOLS ON THE OP1, YOU ARE LIABLE FOR YOUR OWN ACTIONS
    Queta, smartbuddy, nerdo and 20 others like this.
  2. Magnetic Nerd
    Jelly Bean Aug 9, 2015
  3. waicool20
    I think so? I'm not to sure but I think it is. Or it's at least the official fanmade OP China forums
    biltoad likes this.
  4. Funk Wizard
    Moderator Moderator Aug 9, 2015
    biltoad and blueq like this.
  5. blueq
    Honeycomb Aug 9, 2015
    Jasmohit and biltoad like this.
  6. LifelessLewis
  7. waicool20
    That I am not sure, please try it at your own risk. If it were me I wouldn't do it and stick to Oxygen first until the XDA people get fired up :) Though if you do do it then please report ;)
    LifelessLewis likes this.
  8. LifelessLewis
    LifelessLewis , Aug 9, 2015 :
    I'll try it at some point :) my internet is being unreasonably slow today -_- I'll let you guys know, I broke my normal oxygen ROM when I was modding it so I'm stuck with cyanogen nightlies for now until I fix it. So I might as well try :) I'll let you all know :)
    Edit: on second thought I probably won't yet because it's not a port is it, just the ROM built for the 2 :( hopefully someone here can make a port for us One users quicker than they do haha. Unless I'm mistaken and this is the port?
  9. waicool20
    Though I have a question, are One roms compatible with Two roms or do I have to modify some things?
  10. KforHorizon
    KitKat Aug 9, 2015
  11. LifelessLewis
    Pretty sure things need to be changed just like any other ROM would. In the vr launch Cat was saying that they're making a port of Oxygen 2.0 for the One so I would assume that some work needs to go into it. Although I know nothing about porting ROMs haha.
    99% sure it does :(
  12. waicool20
    lol I was just asking the same question, looks like no you have to modify some things first
  13. rikardo1979
    Community Veteran Aug 9, 2015
    KforHorizon, Dr. Indest and rphlfjrd like this.
  14. waicool20
    Well it's in the OP2 section is it not? Also says it in the title...I'll add it anyways.
  15. hulabalua
    Ice Cream Sandwich Aug 9, 2015
  16. bubu83
  17. rikardo1979
    rikardo1979 , Aug 9, 2015 :
    well, is for your safety as some may claim damaged OPO by flashing ROM which is for OP2 :)
    its not clear from your 1st post
    Thanks
    rphlfjrd and Dr. Indest like this.
  18. stupidthursday
    Eclair Aug 9, 2015
  19. Dr. Indest
    Lollipop Aug 9, 2015
    rphlfjrd likes this.
  20. rphlfjrd
    Lollipop Aug 11, 2015
    rphlfjrd , Aug 11, 2015 :
    Nice find! :D/
    I suggest this thread to be pinned as some users already have the 2 and might want to root right away. :)
