OnePlus Two display touch problem
  1. ng2000
    Gingerbread Nov 8, 2015
    ng2000 , Nov 8, 2015 :
    Hi,
    I got my OnePlus2 on tuesday and the touch reacts very laggy (or somtimes not) so i removed the new screen protector but doesnt work better, support ticket is open but no really response so i have to wait for two weeks to get remote help.
    Can anyone tell me what i can test to be sure if its a software or hardware problem.
    My OnePlus One works fine so my fingers wont be the problem ;)
    regards Martin
  2. Cuerex
    KitKat Nov 8, 2015
    Cuerex , Nov 8, 2015 :
    queeze the display a bit on some touch responsive test bench, like 10 finger testing apps and see how it reacts. the last thing i'd try would be complete wipe and rom flash
  3. Tokolozi
    Nougat Nov 8, 2015
    Gaurav Rohilla likes this.
  4. ng2000
    had already cleared and wiped without success, the problem was present on first power on moment as i told the op support, but they told me to clear and wipe what i´ve done, after that procedure no change.
    which app i can test a 10 finger touch test?
  5. Tokolozi
    Nougat Nov 8, 2015
    Tokolozi , Nov 8, 2015 :
    Just touchscreen test but i think there might be one under engineering mode (dial *#808#*)
    Tobikage likes this.
  6. hugogamelas
    hugogamelas , Nov 8, 2015 :
    I had the same issue on my OP2, and the solution was replacing the phone.
    The replacement device works great, havent had any issues yet.
    Here is how you can test your touch screen as per CS instructions:
    "Please dial *#808# in dial board of your phone. You should move into manual test. Then please do touchscreen test. Please let me know if your phone can work normal in such condition. If not, it should be a hardware issue."
    If you draw nice and curvy lines but sometimes the screen registers straight lines connecting points where your fingers have swiped then it is a screen problem and the phone must be RMA'd.
    Good luck!
    ng2000 and Gaurav Rohilla like this.
  7. ng2000
    i´ve tried TouchScreen test
    HandWriting - looks fine
    TouchScreen_Verification Point and Line - most looks fine
    TouchScreen auto test - PASS
    as for example when i wanna dial a number klick on some website or write a text eg sms about 20% of my finger taps were not recognised.
    the "system" buttons (screens, home and back) always works fine
    i´ve redone the handwriting test and then i see some lags but they look like system hung - is there any feature or option to see how the cpu and gpu load is?
  8. Tokolozi
    Nougat Nov 8, 2015
    Then it doesn't sound like a hardware issue, you can always reflash the rom instead of just clearing cache now since it sounds software related.
  9. ng2000
    is there any manual available howto reflash the rom?
    i´ve already downloaded all support files (some GByte big)
  10. Mohit Patharkar
    Cupcake Nov 8, 2015
    Mohit Patharkar , Nov 8, 2015 :
    Guys.. I received my oneplus 2 in top shape but 2 days down the line my fingerprint scanner/home button stopped working.. Like it isn't even responding in the add fingerprint option.. I cleaned it but the problem persists.. Is this a software issue or should I put my phone in for replacement.. Please guide me..
    Thanks
  11. Tokolozi
    Nougat Nov 8, 2015
    Search for it on the forum. Enough threads about it.
  12. ng2000
    Gingerbread Nov 10, 2015
  13. Aiur
    Honeycomb Nov 10, 2015
    Aiur , Nov 10, 2015 :
    https://forums.oneplus.net/threads/touchscreen-sensibility-problems.385516/
    ng2000 likes this.
  14. vkubal
    Cupcake Nov 11, 2015
    vkubal , Nov 11, 2015 :
    Great
  15. ng2000
    Gingerbread Nov 11, 2015
  16. ng2000
    Gingerbread Nov 14, 2015
  17. ng2000
    Gingerbread Nov 17, 2015
    ng2000 , Nov 17, 2015 :
    Some news, i´ve had the remote session, problem for touch was the OTA so they did a full rom install to 2.1.1, it was much better bute at least the OTA to 2.1.2 solved this problem - and create others ;)
    regards Martin
  18. mikechg
    Cupcake Nov 19, 2015
    mikechg , Nov 19, 2015 :
    Hi guys, new here :)
    Reading about the unresponsive screens, could it be that the OP2 screen is slightly (ever so slightly) warped?
    I noticed my display wasn't completely flat when I seen the reflection of, say the edge of a door, or something that is flat but appears distorted on the reflection on the OP2.
    Does anyone else have a slightly concaved/warped/not entirely flat mirror like reflection on their OP2? Or is it just me? :(
