oneplus two heating up
is ur oneplus two heating up???
  1. yes
  2. no
Results are only viewable after voting.
  1. akshay3
    Froyo Sep 24, 2015
    akshay3 , Sep 24, 2015 :
    1) guys i wanna know, its only my phone that heats up a lot or its with everyother op2
    2) other thing is my op2 speaker dosen't sound loud i could hardly hear something from it
    3) pllz share ur reviews about it and let oneplus two support team know the issue regarding phone heating up and the speakers
    4) guys pls share ur reviews with us...:) can update can cure our problem?
  2. leelajagadish
    Jelly Bean Sep 24, 2015
    leelajagadish , Sep 24, 2015 :
    The 1 and 2 are preloaded features.... Everyone gets them
    1 is because of 810 Snapdragon
    2 is because of mono speaker(right side)
    akshay3 likes this.
  3. saivarun12
    Gingerbread Sep 24, 2015
    saivarun12 , Sep 24, 2015 :
    Firstly, if you had updated to the recent OTA updates, then you must not face the heating issue....
    I only felt warm at the aluminium part and little warm at the back when watching HD videos, continuous browsing... But its not too heating... Another notable point is that the way the device cools down is really mind boggling..
    Yes I am also disappointed with the speakers...
    akshay3 likes this.
  4. akshay3
    Froyo Sep 24, 2015
    dose software update can cure it?
  5. leelajagadish
    To some extent...
    They are trying to undercloak the processor with best performance matching...
  6. asp7
    Froyo Sep 24, 2015
    asp7 , Sep 24, 2015 :
    My device gets a little bit warm while playing games on the back and the aluminium part. Other than that the device is working properly.
  7. jakerockwell4s
    Eclair Sep 24, 2015
    jakerockwell4s , Sep 24, 2015 :
    Don't make much of an issue for the temperature rise. All the top end phones heat up under fair usage.
    Don't capsize for this heating issue stereotype!
  8. Harpal225
    Harpal225 , Sep 24, 2015 :
    if we start considering these things then in this price range all the phones are same. OP2 still has upper hand
    jattsingh likes this.
  9. aakash.karkera
    aakash.karkera , Sep 24, 2015 :
    EVEN MINE HEATS UP .... WITH MODERATE WIFI THE HEAT IS BEARABLE BUT WITH 3G ON IT BECOMES TOO HOT AND UNCOMFORTABE TO HOLD.. PLANNING TO RETURN THE PIECE TO AMAZON
  10. jattsingh
    Eclair Sep 24, 2015
    jattsingh , Sep 24, 2015 :
    you are right
  11. akshay3
    Froyo Sep 25, 2015
    akshay3 , Sep 25, 2015 :
    im not making an issue, its just that oneplus should know their customers problems so that they can have a proper update about the problems regarding customers have - its simple, "to change something,u need to do something" AND its better than not creating any ISSUE :)
    rupeshwar and jakerockwell4s like this.
  12. rohra
    Gingerbread Sep 25, 2015
    rohra , Sep 25, 2015 :
    any phone heats up when u use it a lott (Gaming + LTE ).. and also depends on the exposed temp
  13. sridharmreddy
    sridharmreddy , Sep 25, 2015 :
    Forget heating, my phone doesn't even get warm. 3G, Wifi, youtube, apps, long calls.. All done. Just one thing though, I have't started gaming yet.
  14. rohra
    luckily i will never use my op2 for gaming.. i prefer a console for tht
  15. Prateek13
    Donut Sep 25, 2015
    Prateek13 , Sep 25, 2015 :
    By speaker you only mean the loud speaker or earpiece volume is also low(i.e. while making call is the volume low ) ?
  16. OneforAmit
    Cupcake Nov 28, 2015
    OneforAmit , Nov 28, 2015 :
    Sorry dear..i hv used lot of smart fones and have never face heating problem...nt evn minor heating... Unfortunately i strted using it after almst one mnth of prchse...nd the vry first day...its screen and metal covering of camera is heating a lot...dnt knw if I still have a device replacement option....
  17. James Mathew
    Eclair Nov 29, 2015
    James Mathew , Nov 29, 2015 :
    Just check the user reviews of phones available on the net for purchase , you can see major chunk of complaints regarding any phone is the heating issues especially the ones with SD 615 series processors.
