OnePLus two still not ringing
  1. pritpal4321
    Cupcake Jun 10, 2016
  2. MouhamadBzou
    Donut Jun 10, 2016
    MouhamadBzou , Jun 10, 2016 :
    Try to change to Priority or Silent and back to All notification , then volume up or down,
  3. MouhamadBzou
    Donut Jun 10, 2016
    Update ,
    in my case it was an app issue , I downgraded to Lollipop and had the same issue after resorting my apps backups,
    I inspected my apps, one by one , and was surprised that it was cause by one of my apps that I've been using for long time on my old phone without an issue,
    Anyway , I now upgraded to the latest version, and don't have the ringing issue ,
  4. borussia
    Froyo Jun 10, 2016
    borussia , Jun 10, 2016 :
    How do I reset the ringtone
  5. Spannaa
    KitKat Jun 10, 2016
    Spannaa , Jun 10, 2016 :
    You could try looking in settings > sound & notification...
  6. borussia
    Froyo Jun 10, 2016
    Did it, but can't find anything - Ths anyway
  7. Hassan_Abdul
    KitKat Jun 10, 2016
    Hassan_Abdul , Jun 10, 2016 :
    not "resetting" was meant but : choose a ringtone again... is in "choose ringtone"
  8. Yash.parekh
    Gingerbread Jun 10, 2016
  9. MouhamadBzou
    Donut Jun 18, 2016
    MouhamadBzou , Jun 18, 2016 :
    try changing the alert slider up and down , and press the volume buttons up and down to make sure it is not on the lowest settings,
  10. chzetzl
    Honeycomb Jun 18, 2016
    chzetzl , Jun 18, 2016 :
    This only helps till the next reboot of the phone. What can i do? A factory reset is no option, because of security apps, that cause financial loss, that no one refunds, or does someone?
  11. Yash.parekh
    Gingerbread Jun 19, 2016
    Yash.parekh , Jun 19, 2016 :
    Already did that..... no change
  12. sandhya rani narayan
    Cupcake Jul 4, 2016
    sandhya rani narayan , Jul 4, 2016 :
    Have been having the sa problem from the time I installed the recent update. Have missed many important calls because of this
  13. Shao Liu
    Cupcake Jul 5, 2016
    Shao Liu , Jul 5, 2016 :
    sliding the left button up and then back down and the ringtone should be back to normal. you need to do this everytime you reboot your phone. not sure how to fix it permanently though
  14. kaarthy84
    Cupcake Jul 5, 2016
    kaarthy84 , Jul 5, 2016 :
    Keep the ringtone volume adjusted.. move the slider to Priority mode.. reboot the phone.. now move the slider to All Notification.. You will be able to hear when the phone rings.. this worked for me..
  15. caprisco
    Cupcake Jul 24, 2016
    caprisco , Jul 24, 2016 :
    Ok found a solution that worked for me.
    Goto System settings > sounds & notifications > app notifications > phone > switch the Treat as priority to ON.
    This should enable the edit mode for Priority settings. Change this from None to Calls from anyone.
    This should work. I just found this so documenting before I forget the steps..
  16. VickySourabh
    Froyo Jul 25, 2016
    VickySourabh , Jul 25, 2016 :
    For Ringtone issue the below steps might fix the issue
    Set the phone on priority notification, and restart your device and set it back to general mode. The phone will start to ring after that.
  17. allanbjerrum
    Cupcake Jul 25, 2016
    allanbjerrum , Jul 25, 2016 :
    I had the same symptoms and this worked for me also. I consider it a bug in the OP2 version of Marshmallow.
  18. TheHamburglar433
    Cupcake Jul 26, 2016
    TheHamburglar433 , Jul 26, 2016 :
    Yeah I'm also getting the same problem and the only way i found to go arround it is to slide the notifications slider to "silent" and then back to "all notifications", although you have to do this every time you reboot/turn on your phone. Hope One Plus gets this OS bug fixed ASAP in the next OS update.
    #38
  19. qtalky
    Cupcake Jul 30, 2016
    qtalky , Jul 30, 2016 :
    My OP2 on marshmallow does not ring either. Interestingly, when I try to access the sound and notification settings on the stock dialer app, the page crashes everytime
    #39
  20. mehbub1989
    Honeycomb Aug 30, 2016
    #40
