OnePlus Two Touchscreen issues.
  1. xandery
    Cupcake Oct 20, 2015
    xandery , Oct 20, 2015 :
    Got a link on how I can try this? I got no idea what I'm doing tbh, do I need to root to downgrade?
  2. X1y3y2
    Gingerbread Oct 20, 2015
    X1y3y2 , Oct 20, 2015 :
    Can you provide a link to dl 2.0.2?
  3. MiguelPlus
    Froyo Oct 20, 2015
    MiguelPlus , Oct 20, 2015 :
    Nah, your problem isn't similar to ours. My phone came out of the package with this issue. I still had to update the phone. I remember because I was hoping that might just fix it. But it didn't... Also, when I toggle pointer location on (under developer options) I can see the line doesn't come behind but when I draw curves, the lines are angular and irregular. This is because it stops registering touch at some point, and starts in another. you can try this out if you want. It's hard to describe.
  4. MiguelPlus
    Froyo Oct 20, 2015
  5. X1y3y2
    Gingerbread Oct 21, 2015
  6. loulouboy
    Ice Cream Sandwich Oct 21, 2015
    loulouboy , Oct 21, 2015 :
    Truth hurts doesn't it
  7. xestz
    Cupcake Oct 21, 2015
    xestz , Oct 21, 2015 :
    Just try it. Very smooth but the problem are still. Anybody try another rom like CM or another?
  8. aenews
    KitKat Oct 21, 2015
    aenews , Oct 21, 2015 :
    Have you tried reinstalling the entire ROM? No I'd say Stock OxygenOS 2.1.1+Boeffla is the best possible combination. Maybe in the future there will be a Boeffla release for CM/AOSP.
  9. MiguelPlus
    Froyo Oct 21, 2015
    MiguelPlus , Oct 21, 2015 :
    2 more days and they will try to fix mine. But I already know this:
    So I'm not going to flash kernels/roms/recoveries because I KNOW I'll have to send it back :/
  10. Scalpa79
    Scalpa79 , Oct 21, 2015 :
    Hi,
    I received my OnePlus Two yesterday and after the Oxygen update, I also encountered this severe touchscreen issue. It's very disappointed for a new phone and reflects the non-professionalism of the developers to deliver an unstable version.
    However, I manage to "solve" temporary this problem by switching off all gestures in settings. Hope this will help users...
  11. MiguelPlus
    Froyo Oct 21, 2015
    I tried that as well, didn't work tho.
  12. Scalpa79
    Cupcake Oct 23, 2015
    Scalpa79 , Oct 23, 2015 :
    Indeed. I thought when I tried first but you're right, it doesn't help at all. It's fun to have a brand new phone you can't use :) I hope that developers will use the force soon to solve this bug!
  13. ElfStone
    Ice Cream Sandwich Oct 23, 2015
    ElfStone , Oct 23, 2015 :
    Howdy!
    I had the same touchscreen issues. Switched to AK kernel and all my problems are gone.
    I suggest you try it and see if it works for you also. The overall experience improved greatly on my 1+2 :)
    Here is the link:
    http://forum.xda-developers.com/oneplus-2/orig-development/kernel-ak-t3208617
  14. fkur2943
    Cupcake Oct 27, 2015
    fkur2943 , Oct 27, 2015 :
    Will installing kernel void warranty? Currently in the process of RMA, hopefully is not hardware/rounding issue
    I am running Oxygen 2.0.2. and so far, it does not have touch screen issue.
    However,
    the finger print does not work,
    home button does not work ( to go back home you can enable under setting for double tap on back button)
    Camera is slow and sluggish
    Clear app button is missing.
    Other than that, the 2.0.2 has no touch screen issue, it smooth.
  15. chriscam2
  16. 0leg
    Donut Oct 28, 2015
    0leg , Oct 28, 2015 :
    That's exactly my observation. I had no issues with touchscreen before the 2.1 update. I really hope they'll fix it eventually.
  17. ElfStone
    Ice Cream Sandwich Oct 28, 2015
    ElfStone , Oct 28, 2015 :
    WHy are you still on 2.0.2? The 2.1.1 has fixed some of the issues that they had, at least the ones in regards to the camera.
    And NO, installing a different kernel does not void the OnePlus 2 warranty.
    I would suggest you upgrade your phone to 2.1 , install the kernel and then the OTA to 2.1.1 :)
  18. Aiur
    Honeycomb Oct 28, 2015
  19. xandery
    Cupcake Oct 28, 2015
    xandery , Oct 28, 2015 :
    For an update to the people following this thread with similar issues. Just finished a remote session with oneplus, they downgraded the phone to 2.0.2 which cause my home button to not work. Then they had me upgrade to 2.1.1 again to fix the home button and it seems to be working ok for a couple of hours use, will continue to watch the touch screen closely to see if the problem arises again.
    #39
  20. fkur2943
    fkur2943 , Oct 28, 2015 :
    Thanks for the info for warranty.
    Oxygen 2.1 or 2.1.1 fixes those issues, the finger scanner and sluggish camera. However, my touch screen getting slower response, that's why i downgrade to 2.0.2
    For those who still suffers touchscreen issue, here is the fix (at least for me)
    Unlock bootloader,
    Install Root
    install TWRP
    Right now I am running Resurrection Remix Lolipop 5.1.1 r24. So far, much better than the stock Oxygen.
    Fixes the touch screen issue,
    more customization,
    home button works,
    however, the fingerprint does not,
    laser auto focus works.
    http://forum.xda-developers.com/oneplus-2/development/rom-resurrection-remix-t3208988
    #40
    ElfStone likes this.
