2
OnePlus USB-C headphones not working with 7 Pro
  1. rahulkshinde
    Froyo Aug 11, 2020
    rahulkshinde , Aug 11, 2020 :
    I am facing the same issue, I have the Wireless Z so do not use the USB C type often, but I tried today and it's not working. If I flip the connector there is continue sound like a pulse but no actual content sound in earbuds. I tried with another phone(Samsung A50s ) and earphones are working correctly.
    So defiantly Software issue.
  2. O1601661484021
    Cupcake Oct 2, 2020
    O1601661484021 , Oct 2, 2020 :
    Same issue... Using OnePlus 7t and OnePlus adapter to connect by earphones....it was working fine before.....then few months back encountered this problem, tried few ways which I don't remember now... again the same problem for past 5days..I can connect to my bluetooth but not the wired headset via adapter .. I couldn't even see the headphones symbol when connected....
    @ONEPLUS 7T please help us...
  3. Atul Menon
    Gingerbread Oct 3, 2020
  4. #24
    unknown2078 likes this.
  5. unknown2078
    Cupcake Oct 23, 2020
    unknown2078 , via OnePlus 8 , Oct 23, 2020 :
    there must be an update or something that i don't have to turn otg on every time i connect a usb c headphones
  6. H1606379331300
    Cupcake Nov 27, 2020 at 1:38 PM
    H1606379331300 , Nov 27, 2020 at 1:38 PM :
    I also now have this same issue (on 7t), and have tried the above with no success. It happened immediately after the update to 10.0.15. so i assumed it was related to that. I contacted oneplus and was told to 'Reset my app preferences' and 'reset the network'. All that did was make me have to re-enter my wifi passwords, pair all my bluetooth devices and turn off all the annoying notifications that every app thinks you need to know.
    I went back to them straight away saying that had not worked but radio silence ensued . I had this on a OP3 years ago through a headphone socket, cant believe they still suffer with the same issue.
    So next phone .....Dual SIM Samsung?
  7. tctayal
    Cupcake Nov 27, 2020 at 1:44 PM
  8. U1606186676254
    Cupcake Nov 30, 2020 at 8:55 AM
    U1606186676254 , Nov 30, 2020 at 8:55 AM :
    Hi everyone.
    I've the same issue with my earphones...We can listen music and all...But for phone calls Mic doesn't support...
    OTG doesn't change anyting.
    First I thaught it was a mecanical issue on the connector but the charge works well.
    I plugged the earphhones on a desktop and they work well too.
    even I've checked with other companies mobiles and earphones work well mic supports..
    So now, I'm more guessing a software issue or device issue ?
    My Configuration :
    Phone: OnePlus 7T
