OnePlus USB Cable problem!
  1. rishibb
    Gingerbread Oct 25, 2014
    rishibb , Oct 25, 2014 :
    the usb cable that came with my OPO is usefull only to charge the one.
    On connecting to the laptop, it charges.... does not let me access the phone for media transfer.
    i went to settings> storage > USB computer connections>and clicked on Media Device (MTP)
    the system does not recognize the phone anymore... i have been using the phone& cable only since a week and there are no cuts or external damages or folds!
    even when i got the phone, i had trouble connecting and transferring data using the cable.
    my system is windows 8.... post a week all that this cable can be used for is charging and not a usb cable
    Can i get a replacement? if so ... how?
    anyone else having this problem?
    PrashantRev likes this.
  2. carbine30
    Marshmallow Oct 25, 2014
  3. yupasana55
    Ice Cream Sandwich Oct 25, 2014
    yupasana55 , Oct 25, 2014 :
    no problems here, can use it to easily access the One!
  4. Hanson Lee
    Hanson Lee , Oct 25, 2014 :
    You must have USB debugging enabled.
    Before that, developer settings by going into About phone and pressing Build number.
  5. jan110968
    Jelly Bean Oct 25, 2014
    jan110968 , Oct 25, 2014 :
    I dont think its the cable
    Try turn off the phone now put in usb cable that u have connectet to ur pc turn on the phone an see if it doesnt find it now
  6. JuanL
    KitKat Oct 25, 2014
    JuanL , Oct 25, 2014 :
    Settings - about the phone - tap build number 7 times
    Settings - developer options - Usb debugging (check).
    Try again
  7. rishibb
    Debugging is on.... :confused:
  8. jan110968
  9. greendragon
    greendragon , Oct 25, 2014 :
    Ive used my usb to download tunes from pc. Windows 7 tho. Can't believe it would be charge only.
  10. rishibb
    EXACTLY!!
    further on it is a cable problem ar the usb part end, i have to push the cable up one inserted in the usb slot and hold it in that position.... so the usb input end has a problem!
    Just discovered this! what do i do now... it keeps disconnecting!
  11. borceg
    Honeycomb Oct 25, 2014
    borceg , Oct 25, 2014 :
    Disable USB debugging if you want to use your phone as an external storage aka flash. Your cable is ok.
  12. vr_chaos
    vr_chaos , Oct 25, 2014 :
    Had the same problem, have you installed adb and/or Samsung Mobile Devices driver on your computer?
  13. jan110968
    Do u have another cable to try with
  14. greendragon
    Use any quality usb cable that does data
  15. rishibb
    i did try with a friend's cable and works fine.... sadly need to buy another cable!! OnePlus should work on its QUALITY END... will try and replace cable one service center list for India is released :/
    really liked the look of the cable, now disappointed!
  16. jan110968
    U can try i dont know how to write it but im trying
    Try screese the usb end a litle with something not to mutch just a litle
