OnePlus Warp Charge 30 Car Charger IN - is this compactible with 8T? via OnePlus 8T
  1. prateek.bhargava
    Cupcake Mar 15, 2021
  2. drl431
    Community Hero 2020 Mar 15, 2021
  3. prateek.bhargava
    Cupcake Mar 16, 2021
    prateek.bhargava , via OnePlus 8T , Mar 16, 2021 :
    Thanks for reply. Any news regarding the launch of wrap charger 65 in this ?
  4. KaranRIyer
    KitKat Mar 16, 2021
    KaranRIyer , Mar 16, 2021 :
    For Car Charger? Keep looking i guess. Never know. Keep a watch at store.
    prateek.bhargava likes this.
  5. prateek.bhargava
    Yes for car charger only. I am hoping for its launch soon if it is not yet.
  6. KaranRIyer
    KitKat Mar 16, 2021
    Well you can post it as a suggestion. Thats best we can do now.. If you don't know how to you can refer the below link said:
    https://youtu.be/iNjApH5klq0
  7. prateek.bhargava
  8. KaranRIyer
    KitKat Mar 16, 2021
  9. prateek.bhargava
    Done. Thanks for the details, hope my suggestion would be taken seriously!
    KaranRIyer likes this.
  10. KaranRIyer
    KitKat Mar 16, 2021
    You never know. 👍
  11. JvdBeemt
    Ice Cream Sandwich Mar 18, 2021
    JvdBeemt , via OnePlus 7T , Mar 18, 2021 :
    Don't know if the cabeling of your cigar plug is up to that.
    65 watts means 13 amps at 5 volts so about 7 amps at 12 volts on the car wires most cicar plug will probably have fuses that will not allow that kind of a load for safty reasons of possible meltting the wires
    prateek.bhargava and KaranRIyer like this.
  12. JvdBeemt
    Or is the dc voltage on the 65 watt charger higer ?
    I don't own a one plus 8 so I can't tell.
    Volage and amps of dc output are normaly on the powerbric delivverd with the phone and the arihtmatic to convert it to the twelve volt system of a regular car is simple.
    In your owner manual of the car you can find the fuse limit of the auxilary outlet ( cigaret lighter plug).
    Hope this helps.
    And like already stated by somone the 30 watt charger is compatibel and that keeps the amps down to a level that can be managed by most modern cars.
  13. oTeMpLo
    Froyo May 6, 2021
  14. oTeMpLo
    Froyo May 6, 2021
    oTeMpLo , May 6, 2021 :
    the only wa is 12 V to mains (230v in eu) inverter and normal 65W warp charger.. but solution is big :/
