197
OnePlus Warp Charge 65: A Day's Power in 15 Minutes
  1. darren190390
    Honeycomb Sep 27, 2020
  2. Dhr888
    Honeycomb Sep 28, 2020
  3. brian.sedore
    Ice Cream Sandwich Sep 28, 2020
    brian.sedore , Sep 28, 2020 :
    I was just going to ask whether or not these crazy, fast charging speeds are ever a concern. This is kind of reassuring.
  4. K1599897097343
    Cupcake Sep 28, 2020
  5. Ritam03
    Eclair Sep 28, 2020
  6. SkippyCavanugh
    Froyo Sep 28, 2020
    SkippyCavanugh , via OnePlus Nord , Sep 28, 2020 :
    camohan
    Noice. I am waiting for the day when I only show my device to the charger and it gives me a day's power.
    Jokes apart - I am concerned about the heating while charging and glad this has been thought about.
    Also, I am not sure if this is a right place to ask, but would the adaptor design change due to this? India already has a larger size adaptor.​
    I think there wouldn't be any issue with the heat, as OnePlus uses the Oppo VOOC (or licensed to OnePlus as Warp Charge) which is designed to charge the devices much faster with less heat generation. The Wikipedia page of VOOC States that unlike the Qualcomm Quick Charge technology, which increases the voltage during fast charging, VOOC uses a higher current than normal USB 2.0 charging; VOOC operates at 5 volts and 4 amperes to match the internal battery voltage, which removes the need of regulating the voltage inside the mobile phone. I personally think that OnePlus obviously would have considered heat dissipation while designing the new warp charge, so I think it would be safe to assume that heat wouldn't be an issue with the new Warp Charge. As for the Adapter size, OnePlus really needs to reduce the size. My house has that alternate plug points (Buttons are adjacent to plug) and it really gives me a hard time to keep the Adapter in place as it doesn't fit in the plug LOL
    Mamta248 likes this.
  7. charan_kasyap_85
  8. Mamta248
    Gingerbread Sep 28, 2020
    Mamta248 , via OnePlus Nord , Sep 28, 2020 :
    Nope. It will only work on 8t
  9. Mamta248
    charan_kasyap_85 likes this.
  10. srini0301
    Jelly Bean Sep 28, 2020
  11. hslayal
  12. akshnoty
  13. virendra aggarwal
  14. gokulkpv97
    Eclair Sep 28, 2020
    gokulkpv97 , Sep 28, 2020 :
    So you dont take your phone while going to take a shit? Are you human?
    Mark Falsing likes this.
  15. Basudev7
    Gingerbread Sep 29, 2020
  16. Nipun Chowdhury
    Eclair Sep 29, 2020
  17. O1601351262555
    Cupcake Sep 29, 2020
  18. Karteek_B
  19. ojhaab
    Donut Sep 29, 2020
    ojhaab , via OnePlus 5 , Sep 29, 2020 :
    What is the possibility of the phone to explode. Reason the daily charging with such a power for avg life of a phone been 3 years.
    The amount of power will go on daily basis, due which heating will come as an issue. Not sure if we are innovating then have a serious cooling pad.
