OnePlus Wireless bullets 2.
  1. Merlinlegend
    Eclair May 29, 2019
    Merlinlegend , May 29, 2019 :
    OnePlus Wireless bullets 2 doesn't work quick pair with my OnePlus 6T. OnePlus liar again.
  2. Priyanshu Sharma
    Jelly Bean May 30, 2019
  3. Muhsin_Sultan
    Ice Cream Sandwich May 30, 2019
  4. G_Prateek_Luhadiya_kAyx
    Donut Jun 6, 2019
  5. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Jun 6, 2019
    SirBoss likes this.
  6. Priyanshu Sharma
    Jelly Bean Jun 6, 2019
    Priyanshu Sharma , Jun 6, 2019 :
    Press and hold both the Power Button and Pause button until you see the light blinking... If this doesn't help then go to the nearest service centre and get it checked... They'll replace with a new one for free if there is any fault...
  7. Priyanshu Sharma
    Who told you?
  8. Muhsin_Sultan
    Ice Cream Sandwich Jun 6, 2019
    Kytharsis likes this.
  9. Priyanshu Sharma
    Ahh my bad!!
  10. B1559917359175
    Cupcake Jun 7, 2019
  11. Priyanshu Sharma
    Jelly Bean Jun 7, 2019
    Priyanshu Sharma , Jun 7, 2019 :
    Yes no problem, it'll work fine..
    Kytharsis and B1559917359175 like this.
  12. B1560594871288
    Cupcake Jun 15, 2019
    B1560594871288 , Jun 15, 2019 :
    Hello esteemed community of oneplus,
    I currently have an op6t and am planning to buy oneplus bullets wireless 2 to go along with them... I have a series of questions and would be grateful to have them answered. so here they are:
    1. can I use my dash charger which came with my op6t to charge the bullets without damaging them?
    2. not having a warp charger, what difference will that make while charging them?
    3. what if I charge them using the cable provided with the buds and a laptop? how much time will that take then?
    thanks guys and that's it.
  13. Mohammed_Mousa93
    Donut Jun 23, 2019
    Mohammed_Mousa93 , Jun 23, 2019 :
    1- yes you can, I charge them using dash charger, using the cable provided with op6t
    2- idk, but 15 mins = 100% [e]1f44d[/e], I think there is no difference
    3- I'm going to try that as soon as possible
  14. B1560594871288
    Cupcake Jun 23, 2019
    B1560594871288 , Jun 23, 2019 :
    thanks [e]1f60a[/e]
  15. B1545984958653
    Cupcake Jun 29, 2019
    B1545984958653 , Jun 29, 2019 :
    Hi guys! I've become a user of this device. I have a question. I can switch to another bluetooth device using a double tapping on that special button. But after that I can't to switch back to my OP6T. What's the problem?
  16. Praty_28
    Jelly Bean Jun 29, 2019
    Praty_28 , Jun 29, 2019 :
    Yes this happens on my 3T aswell. After i connect to my laptop using double click power button, the next double click disconnects the buds from the laptop but does not automatically reconnect to my phone. I have to go into bluetooth settings and manually connect even after double click of the power button.
