OnePlus X - Bluetooth/WiFi Slowdown
  1. siguy87
    Gingerbread Jan 14, 2016
    siguy87 , Jan 14, 2016 :
    This is a good indicator that it's a software issue.
  2. SimonFullerImagery
    Jelly Bean Jan 14, 2016
  3. MochiFX
    Donut Jan 17, 2016
    MochiFX , Jan 17, 2016 :
    Funny thing is I never had this issue with my OPO using it with my Bluetooth activity tracker 24/7.
  4. dreniacdre
    KitKat Jan 17, 2016
    dreniacdre , Jan 17, 2016 :
    I agree. But how could one replicate this?
    I am using bluetooth speakers, miband and miscale. And I don't have this issue.
    Just on a side note: I do have an issue with using ipv6 on my accesspoint though.
    I couldn't get DNSv6 resolving working properly. But this is a general Android problem.
    Disabling ipv6 and my wifi is flying. People still having issues with even bluetooth disabled should try this.
  5. dreniacdre
    KitKat Jan 17, 2016
    Maybe @draconus has Oxygen installed on his OPO?
    It would be interesting if he would install COS12.1 instead and see if the issue is gone.
    It would point to an Oxygen bug then.
  6. philiporam
    Cupcake Jan 22, 2016
    philiporam , Jan 22, 2016 :
    Reset phone for the 3rd time. 1 week later the slowdown is back. When are oneplus going to fix this *software* problem?
  7. mifleck
    Cupcake Feb 3, 2016
    mifleck , Feb 3, 2016 :
    Same issue on One plus One, not on oxygen, have only update OTA standard updates. I just dont understand @Carl any idea of a fix?
  8. MochiFX
    Donut Feb 7, 2016
    MochiFX , Feb 7, 2016 :
    Seems like everyone is referring to the BT and WiFi 2.4Ghz bands interfering with one another
  9. MochiFX
    Donut Feb 7, 2016
    I had OxygenOS on my OPO, no issues with signal interference
  10. max.spock
    Froyo Feb 7, 2016
    max.spock , Feb 7, 2016 :
    Same frequency therefore there are some interferences... Lack of WiFi 5ghz doesn't help
  11. jlwest
    Gingerbread Feb 7, 2016
    jlwest , Feb 7, 2016 :
    There is no fix for this...they just run on the same frequency :/
  12. yoyo71389
    Cupcake Mar 4, 2016
    yoyo71389 , Mar 4, 2016 :
    I found that the Wi-Fi and BT in my OPX are using the same MAC address. Would it be the reason?
    (The MAC address of them in my Samsung tablet are slightly different)
  13. philiporam
    Cupcake Apr 17, 2016
    philiporam , Apr 17, 2016 :
    After 3 months of everything working fine the dreaded bug is back. Luckily, my Moto 360 has wifi now so using that.
  14. Saurabh40629
    Honeycomb Apr 19, 2016
  15. janbpunkt
    Cupcake May 4, 2016
    janbpunkt , May 4, 2016 :
    Same issue here with Oneplus X.
    As soon as I turn on the BT to connect my Pebble, the WiFi dies.
    When I use the same setup with a MotoG (v1), there're no issues.
    My Win10 Tab also has no issues with BT and WiFi enabled at the same time.
  16. sirious09
    Cupcake Aug 29, 2017
  17. emailMichael
    Donut Sep 3, 2017
    emailMichael , Sep 3, 2017 :
    Still no update? I have the same Bluetooth/Wi-Fi issue. I HAVE to turn off BT to use Wi-Fi. It's 2017, OnePlus does not support their early customers on their previous products, thanks. I won't have to think too hard with my next device purchase because OnePlus has made it SO clear for their customers. Support is so important to the customer base. I cannot recommend to family & friends the fine support
  18. Kéno40
    Jelly Bean Sep 4, 2017
    Kéno40 , Sep 4, 2017 :
    If you're on OOS 3.1.4, your only chance is to use custom roms to make it work...
    #38
  19. sirious09
    Cupcake Oct 27, 2017
    sirious09 , Oct 27, 2017 :
    Which one Kéno40?
    I tried the AOSP-OnePlus-X-7.1.2 and it still doesn't work.
    #39
  20. mgpa
    Donut Jul 19, 2019
    mgpa , Jul 19, 2019 :
    I am facing the same issue on the lates Stable update of OP6.
    Any solution???
    #40
