9
OnePlus X OxygenOS 2.2.1 Bugs!
  1. mackleroni
    Donut Apr 16, 2016
    mackleroni , Apr 16, 2016 :
    Problems faced
    - phone lag when airplane mode activated/deactivated
    - random vibrations during a call
    - YouTube video lags
    - first&last name shuffle in contacts
    - same sd card issues as before
    Newer bugs
    - slower charging
    - power button delay when turning on screen
    - occasional phone lags
    jai patel and mradul5 like this.
  2. ivanazagra1997
    Froyo Apr 16, 2016
    ivanazagra1997 , Apr 16, 2016 :
    my girlfriend also have some lte/4g problems, is that a bug of the new update to?? They should fix that quickly, she got her phone yesterday, and I am a little worried about this
  3. ScareYa
    Ice Cream Sandwich Apr 16, 2016
    ScareYa , Apr 16, 2016 :
    I have to say I don't suffer from any of the bugs you're talking. But since I don't use Hangouts, Shelf and Youtube (except in a browser) some of them just don't have the chance to 'bug' me. Basically I don't see any difference between 2.2.0 and 2.2.1. Same performance, same battery life (no unusual drain), same charging times. But also the same old problems with Bluetooth, vibration during calls and the mediocre low light performance of the camera. I am still hoping the coming Marshmallow update will cure those shortcomings. It is about time actually...
  4. larrybrains
    Cupcake Apr 16, 2016
    larrybrains , Apr 16, 2016 :
    Mine does not go back up on its own. I have to turn it back up.
    Although for me this is a minor issue compared to the power button not responding, notification delays & general laggyness when switching between apps & home screen.
  5. Frank94
    Frank94 , Apr 16, 2016 :
    Me too! I have same problems with shelf and widgets don't work and become unusable, when i am not connected to internet or after i turn on the phone...
  6. thebntninja
    Donut Apr 16, 2016
  7. Vancrack
    Gingerbread Apr 17, 2016
    Vancrack , Apr 17, 2016 :
    This is why I stopped updating at 2.1.3 there seems to be more new bugs than fixed bugs.
  8. OneMarco
    OneMarco , Apr 17, 2016 :
    My bugs since the beginning :
    Airplane mode lag (better after last updated).
    Contacts sometimes appear deferently from what I saved them.
    Bluetooth phonecalls work fine in any car but can't download contact list.
    Everyonce in a wile some app reeboots
    Love the phone but oxygen os could de a lot better
  9. jayanthramkv
    Eclair Apr 17, 2016
    jayanthramkv , Apr 17, 2016 :
    I'm also facing these issues
  10. shamal666
    Donut Apr 17, 2016
    shamal666 , Apr 17, 2016 :
    I didn't noticed most of the issue listed here.
    But what I'm facing is the draining of battery, can't get a full day. Before update I was getting a day backup very easily but now not at possible.
    Other issue is with data connection that was previously there, but now it is worse by every 5 min data will drop, but the status shows as its connected to network.
    Toomey1 likes this.
  11. Jorge48197
    Jorge48197 , Apr 17, 2016 :
    I thought I was the only one with this issue
  12. bharatkumarchennai
    Froyo Apr 17, 2016
  13. sunny33438
    Froyo Apr 17, 2016
  14. sunny33438
    Froyo Apr 17, 2016
    amirul_lisan likes this.
  15. Moritz Schünemann
    Cupcake Apr 17, 2016
  16. iamtrunal
    Honeycomb Apr 18, 2016
    iamtrunal , Apr 18, 2016 :
    Also face problems with WiFi. Don't see the connected symbol even if connected. Also brightness adjustment issue. Have to again bring down the notification panel to adjust the brightness. Vibrations during calls and Shelf Lag still going on.
  17. zero03
    Eclair Apr 18, 2016
    zero03 , Apr 18, 2016 :
    I have the same issue as well. It only occurs when I'm on LTE connection only. Wifi, works perfectly fine.
    My wifi now takes about a minute or two before it can connect to my home wifi or any saved wifi. Before (with OOS 2.2.0), when I turn on my wifi, it will connect in under 10 seconds.
  18. migueldbr
    Gingerbread Apr 18, 2016
    migueldbr , Apr 18, 2016 :
    I dont know what you guys did to your phones, i have 2.2.1 and dont have any issue with power button, wifi or delayed notifications, so its not 2.2.1 fault...
    #38
  19. astina_55
    Froyo Apr 19, 2016
    astina_55 , Apr 19, 2016 :
    In call vibration -> not solved, wtf !
    Air plane switch lag -> improved but not solved
    Youtbe video start lag -> not solved
    New bugs : volume setting display is not refreshed correctly when you press the volume button during apps executing.
    Volume is in reality correctly reduced or pushed up but display is freezing on the first move.
    Bug ? : noticed some more heat when using hardly the phone. Battery life is still poor. Will doze feature from MM improve something ? let's hope so
    #39
  20. Devendarbukyaa
    Gingerbread Apr 19, 2016
    Devendarbukyaa , Apr 19, 2016 :
    I am lucky, I dont have above all mentioned issues... But sometimes when I pick a call after some time I am getting waiting tone, even though I dont have waiting call.
    #40
    mlknyc likes this.
