Oneplus x power button and volume buttons not working!!
  1. anshuman18
    Cupcake Mar 9, 2016
  2. R.Peter
    Ice Cream Sandwich Mar 9, 2016
    R.Peter , Mar 9, 2016 :
    What does it mean? If you press one of them nothing happens? Or if you press them together has no effect?
    Is the phone turned on?
  3. anshuman18
    Cupcake Mar 10, 2016
    anshuman18 , Mar 10, 2016 :
    If i press single button nothing happens and the phone is turned on..
  4. kjam3
  5. Wanpli
    Cupcake Apr 15, 2016
    Wanpli , Apr 15, 2016 :
    I have the same problem.
    The volume and power button just stopped working.
    Nothing was done to the phone.
    Pressing the buttons and they don't respond.
    Please help me fix this problem.
  6. harshith21
    Froyo Apr 16, 2016
    harshith21 , Apr 16, 2016 :
    @Wanpli Did you try restarting the phone?
    After that if the buttons don't work then I guess it's time to take a trip to the service center.
  7. Wanpli
    Cupcake Apr 17, 2016
    Wanpli , Apr 17, 2016 :
    @harshith21
    The phone was neither charging nor were the volume and power buttons responding. So I couldn't restart the phone.
    What I did.. I let the phone's battery drained completely overnight.
    The next morning I plugged on the charger. Waa lah.. The phone started working normally again :)
    Thanks for Helping out Harshith21 :)
  8. mooners
    Cupcake Apr 22, 2016
    mooners , Apr 22, 2016 :
    my oneplus x has just went the same way volume buttons are power botton not working and the phone isnt charging is the a fix for this.
  9. mooners
    holding the volume up button and power button for 10 seconds restarts the fone and fixed the problem
  10. mlevi
    Cupcake Aug 12, 2016
    mlevi , Aug 12, 2016 :
    I had the same problem and the above answer helped me.
    After I did what mooners suggested I got a "Fastboot Mode" screen, then I long pressed the power button again to boot the phone.
    Cheers.
  11. sionyn2
    Eclair Aug 16, 2016
    sionyn2 , Aug 16, 2016 :
    Yep if you ever get into a situation where your phone or anything electronic gets into a state were it's unresponsive you can usually hold the power button down to start a soft reset.
    Here's a good video explaining the theory of soft power switches
  12. preetamkr
    Eclair Aug 16, 2016
    preetamkr , Aug 16, 2016 :
    I have also face some problems regarding the power button. Some of them are:
    1. Most of the times it becomes unresponsive when i try to unlock/wakeup the phone.Takes quite a while to wakeup feels very annoying:confounded:.
    2.Some times it gets really unresponsive and does not responds to the clicks.It even stops charging.
    Some other issues I faced are :
    Sim 2 says undetected while I can use it.
    These bugs feels like i have been cheated by OP:disrelieved:.
    Hope someday they(Oneplus) will fix'em.
  13. julienmic
    Honeycomb Oct 16, 2016
    julienmic , Oct 16, 2016 :
    Tried it on my OP2, also fixed the problem!
    Thanks a lot!
  14. basuhz
    Cupcake Oct 20, 2016
    basuhz , Oct 20, 2016 :
    Thank you..I was facing the same problem.Neither the phone was starting nor charging up. Tried the same thing what u have suggested and Voila it worked. After pressing power button and volume up button for 10 seconds, it entered into a fastboot mode. Exit from fastboot by pressing power button and volume down button until the mobile restarts.:):)
  15. smosh92
    Donut Oct 24, 2016
    smosh92 , Oct 24, 2016 :
    yeah i think the best play here is to drain the battery and let it die. after that charge it and then restart. if the buttons still don't work, i guess you have to go to the service center.
  16. shashiv
    Cupcake Oct 25, 2016
    shashiv , Oct 25, 2016 :
    I can not increase ringer volume at all... Even with volume bar it's locked at zero...
  17. Wanpli
    Cupcake Dec 20, 2016
    Wanpli , Dec 20, 2016 :
    The problem occurred again..
    This is time i hard restarted the phone as suggested by @mooners and it worked again.
  18. Vykiss
    Cupcake Feb 8, 2017
    Vykiss , Feb 8, 2017 :
    Oh my god, just found this post. Used @mooners solution to the problem and now it works again. Lived with double tap to wake and sleep and not letting the phone to turn off for 2 months and now my power button works again.
  19. mananktm
    Cupcake Feb 9, 2017
  20. G_Malika_Tamim_zyZr
    Donut Jul 1, 2017
    G_Malika_Tamim_zyZr , Jul 1, 2017 :
    if this works, does that mean it's a software problem?
