8
OnePlus5 goes automatically to silent mode randomly
  1. jaskaransinghbindra Cupcake Mar 16, 2018
    #41
  2. TheRealGamer Lollipop Mar 16, 2018
    #42
  3. txumari Cupcake May 14, 2018
    txumari, May 14, 2018 :
    I have the same problem with oneplus5 with 5.1.1
    I have tested clean cache, reset factory...anything works
    #43
  4. prf2k Cupcake Jun 13, 2018
    prf2k, Jun 13, 2018 :
    Have the same issue on o+6 lates oxygen os. 5.1.6. around 2130 every night. Dnd mode comes on from 23 and goes of 6am.
    #44
  5. catap Cupcake Aug 11, 2018
    catap, Aug 11, 2018 :
    Hello
    Did someone manage ro fix this issue or is a hardware problem?
    #45
  6. I1516173681783 Cupcake Sep 27, 2018
    I1516173681783, Sep 27, 2018 :
    Hey friends,
    Two weeks back, my OP5 fell into water. From that time, mob automatically goes to silent mode even if the slide bar is in right position. It goes to silent mode and switches back to normal mode. This keeps happening frequently. I thought I was the only one having this issue cos my mob fell into water. But, many having the same issue saying bug fix is needed. But, I'm not sure if this issue to me is cos the mob fell into water or even I have a bug issue. Please help me out.
    #46
    G_Rendy_Nugraha_vXJZ likes this.
  7. Mu3azOsman Cupcake Apr 28, 2019
    Mu3azOsman, Apr 28, 2019 :
    in 2019, same issue, even after resetting the phone and the new android update and all.
    my op5 is becoming dead
    #47
  8. Mr_Cyrox KitKat Apr 28, 2019
    Mr_Cyrox, Apr 28, 2019 :
    Well the thread was dead till you revived it too...
    Maybe try the solution presented in this very thread?
    #48
  9. G_Rendy_Nugraha_vXJZ Cupcake May 7, 2019
    #49
  10. Waveform Modifier Marshmallow May 7, 2019
    Waveform Modifier, May 7, 2019 :
    If it was the alert slide, no amount of software update will fix it. Maybe contact OnePlus support instead.
    #50
  11. KuhnTucker Donut Jun 4, 2019
    KuhnTucker, Jun 4, 2019 :
    Hi I've been having the problem for the past few days as well. The phone randomly goes into "silent" mode even though the slider is at the "ring position". The slider does feel a little stiff though so it could be that after a year and 9.months the slider finally gave up lol
    #51
  12. MuathA Cupcake Jun 24, 2019
    MuathA, Jun 24, 2019 :
    I've also been facing this issue as well for more than a month now, it's very annoying and it's been happening more and more often.. the phone switches directly from ring to silent mode and skips vibrate mode, and the alert slider is still solid and firm which makes me think it's a software issue..
    #52
  13. G_Venkatamurali_Krishna_ Cupcake Jul 28, 2019
    G_Venkatamurali_Krishna_, Jul 28, 2019 :
    Now I think I understand the problem, after seeing all this posts. looks like it's a combination of hardware and software problem. Actually I am using OnePlus 5 since 2 years without any issues but now suddenly this has started. yesterday when I went to the beach with my daughter some of the water fell on pocket in which my phone was lying. Phone did net get wet completely but a did a bit of it. There was also a bit of sand near hearing space and and some near the charging port. I cleared the sand but looks like the job has already been done for it to work weirdly. And when this dust/sand particles go away over a period not time the phone comes back to normal. I am facing the issue since yesterday only during late evening times, not sure why this happens only at this time. let me wait and see when this stops.
    #53
    MuathA likes this.
  14. arpit.taneja Cupcake Aug 13, 2019 at 11:45 AM
    arpit.taneja, Aug 13, 2019 at 11:45 AM :
    Now I am facing the issue in my OP5 running on 9.0.8 OS. I didn't install any app. Please suggest solution. Thanks.
    #54
