OnePlus6t Charging Port Problem via OnePlus 6T
  1. kiran998
    Donut May 11, 2021
    kiran998 , via OnePlus 6T , May 11, 2021 :
    Hi Friends.....Am using 6T for a very long time.... I have an issue currently like when I connect my wired earphone to a converter and then connect it to my device...when I try to play songs,movies,etc...my earphone is not working....but when I try to charge my device its working fine....Can anyone help me with this.... And is there anyone who is facing the same issue....
    Ps. When I connect my device to a wireless bud or neck band am able to listen music,movies,etc....
    Thanks.
  2. pablofg1978
    Head Moderator Head Moderator May 11, 2021
    pablofg1978 , May 11, 2021 :
    Hello there,
    Try to clean the charging port on your phone with compressed air
    drl431 likes this.
  3. kiran998
    Donut May 11, 2021
    Tried this...but didn't work☹️
  4. pablofg1978
    drl431 likes this.
  5. drl431
    Community Hero 2020 May 11, 2021
    drl431 , May 11, 2021 :
    Then try using a toothpick or similar non-metallic probe. Look for pocket lint.
  6. kiran998
    Donut May 11, 2021
    pablofg1978 likes this.
  7. kiran998
    Donut May 11, 2021
  8. drl431
    Hopefully you can clean out any debris inside the usb-c port, on the phone, which might prevent the charging cable from fully seating.
  9. kiran998
    Donut May 11, 2021
    Okay will try this again....if didn't work will reach the support team....
    drl431 likes this.
  10. Raza_Dawar
    Gingerbread May 16, 2021
  11. Z1541622383921
    Cupcake May 31, 2021
  12. Bittoo06
    Ice Cream Sandwich May 31, 2021
    Bittoo06 , May 31, 2021 :
    Your connector might not be compatible with the device. Try using a different converter.
  13. Raza_Dawar
    Gingerbread Jun 1, 2021
  14. G1551364219501
    Cupcake Jun 13, 2021 at 9:12 PM
