Oneplus7Pro Screen timeout not work via OnePlus 7 Pro
  1. G_bipin_bankar_JUbM , via OnePlus 7 Pro , Jul 29, 2021 :
    The Screen timeout in my phone doesn't engage so it keeps the screen up all the damn.Because of this the phone gets hot and also the battery drains rapidly.
    Checked the developer settings,the saty in whule charging feature is turned off.
    I guess some app is keeping it up.How do i check which app is the culprit?
    rHITkM. likes this.
  2. rHITkM.
    Ice Cream Sandwich Jul 29, 2021
    rHITkM. , via OnePlus 6 , Jul 29, 2021 :
    Please check if the issue persist in the safe mode too ( in this mode 3 party apps will be disable and when you get out of the safe mode apps will work again normally ).
    (1) Steps to boot device into safe mode :
    1. Press and hold power button.
    2. Now press and hold either POWER OFF or RESTART button .
    3. Press OK
    4. Wait for the phone to restart.
    Here check your screen timeout , engaging in tome or not .
    (2) steps to get out of Safe Mode .
    1. RESTART the device.
    Try this if you see any development report here .
  3. Z1612187578731
    Gingerbread Jul 30, 2021
    G_bipin_bankar_JUbM likes this.
  4. #4
    rHITkM. likes this.
  5. rHITkM.
    Ice Cream Sandwich Aug 6, 2021
    rHITkM. , Aug 6, 2021 :
    Did you try to boot into safe mode as I have mentioned here👆.
    If not please try it.
  6. #6
    rHITkM. likes this.
  7. rHITkM.
    In the past have you ever tried to to downgrade you device?
  8. #8
    rHITkM. likes this.
  9. rHITkM.
    What's the OnePlus Launcher version in you device?
  10. #10
    rHITkM. likes this.
  11. #11
    rHITkM. likes this.
  12. rHITkM.
    Now that you have updated it, just clear the cache of the OnePlus launcher and then restart your device.
  13. G_bipin_bankar_JUbM , via OnePlus 7 Pro , Aug 6, 2021 :
    I clear the cache of the oneplus launcher & restart device but issue not fix.
    rHITkM. likes this.
  14. rHITkM.
    Can you share the screenshot of the screen timeout settings page?
  15. #15
    rHITkM. likes this.
  16. rHITkM.
  17. #18
  18. rHITkM.
    Try to Re-flash the current OOS version or try to reset, I think these are the only options.
    Please TAKE BACKUP OF EVERYTHING before proceeding with any of the above mentioned methods.
  19. G_bipin_bankar_JUbM , via OnePlus 7 Pro , Aug 6, 2021 :
    I don't know how re-flashing or resetting the current OOS version.plz Explain to me.
    rHITkM. likes this.
