Onplus 6 Bettry & Lot's of Problems After update
  1. mussaibraheem10@ Donut Jul 15, 2019
    mussaibraheem10@, Jul 15, 2019 :
    Automatically Call Droping After 4/5 Seconds.
    Camera Creash Automatically.
    Taking To Much Time Also.
    one important Thing Bettry Draining So Fast.
    3% Down Without using Any Thing.
    What The Hell iS Going.
  2. Kytharsis Marshmallow Jul 15, 2019
    Kytharsis, Jul 15, 2019 :
    1. Are you on Jio perchance? There seems to be call issues going on with them lately.
    2. Camera version please.
    3. This is normal. Once it reaches close to 90% it'll return to normal if you've calibrated the battery properly.
    19061990 and Maverick2.0 like this.
  3. mussaibraheem10@ Donut Jul 15, 2019
    No Sir Em Mobilink uSer Becouse Em From Pakistan.
    Wel 5 Minute used And Bettry 9 % Down This is Not Good Thing i Think So.
  4. mussaibraheem10@ Donut Jul 15, 2019
    Total Apps Are Baground Data off & Bettry Restricted Mode.
    1 Hour 45 Minute Taking it Gona Full Charge & Just 5 Minute Normly use Like Chacking Alarm Clock And Seeng WhatsApp Bettry Gona Down 9 % This update Not Perfect They Have Many issues.
  5. Promil Kumar Cupcake Jul 17, 2019
  6. Scherpenseel Jelly Bean Jul 17, 2019
    Maverick2.0 likes this.
  7. Promil Kumar Cupcake Jul 17, 2019
  8. Unscribed Eclair Jul 17, 2019
  9. Promil Kumar Cupcake Jul 17, 2019
    Promil Kumar, Jul 17, 2019 :
    Yes, It does but that's the problem.
    Before the update it used to last for around 1.5 Days but now the Standby drain in itself is so much that I doubt if the phone would last a full day.
  10. Unscribed Eclair Jul 17, 2019
    Unscribed, Jul 17, 2019 :
    Can you check if any specific apps are drawing a lot of power?
    A phone with screen turned off should have minimal usage.
  11. G_VIMLESH_RAGWANI_Odot Cupcake Jul 17, 2019
  12. Promil Kumar Cupcake Jul 17, 2019
    Exactly, at standby it should have minimal usage but the drainage is higher than usual and none of the apps seems to be drawing unusual power.
    Just for info: This is after the 9.0.15 update
    mussaibraheem10@ likes this.
  13. Unscribed Eclair Jul 17, 2019
    Yes, I have the same update and same phone, nothing changed for me. Maybe you should backup and do a full reset?
  14. Promil Kumar Cupcake Jul 17, 2019
  15. mussaibraheem10@ Donut Jul 25, 2019
    mussaibraheem10@, Jul 25, 2019 :
    ALert Slider Also Not Working Tottly Silent When Em Trun on Silent Mode Mobile Gone Vibration Mode Silent Mode Removed In This update...?
    Anybody Facing Same issue...?
  16. Kytharsis Marshmallow Jul 25, 2019
    Kytharsis, Jul 25, 2019 :
    I'd worry more about answering your call than the alert slider if I were you.
  17. Arjun Choudhry Gingerbread Jul 25, 2019
    Arjun Choudhry, Jul 25, 2019 :
    Try clearing up your Alert Slider with a thin pin. It is due to dust accumulating in the Alert Slider. There is already a thread about this. Try using the search button next time.
  18. R1528752001541 Eclair Jul 25, 2019
  19. hhristov5911 Cupcake Jul 25, 2019
    hhristov5911, Jul 25, 2019 :
    Hello, I am noticing the same battery drain after the recent update. It doesn't seem normal to me. Please if anyone have information about this problem, let us know.
  20. Kytharsis Marshmallow Jul 25, 2019
    You made two mistakes with this post: no screenshot given and you neglected to find the mega thread in the General Support thread.
    drl431 likes this.
