OP 6 OS issue via OnePlus 6
  1. raisulbappy
    Cupcake Jul 23, 2021
    raisulbappy , via OnePlus 6 , Jul 23, 2021 :
    I've been using OP 6 since 2018. Never have i ever found any serious issues until couple of days back when it took a restart while using and went into "Qualcomm CrashDump Mode". Tried to factory reset and start it using fastboot but none worked. Then took it to expert and they tried using resetting software by flashing and so on but it didn't work. Finally someone said it is a hardware issue with CPU failure and said he might try to fix it by opening up the component. Guess what, it worked and my phone started again. But as it went through factory reset many times so I lost all my data from my phone. And to my utter surprise it went to android 8 and the automatic update isn't working anymore. I tried to update from settings and it is saying it has the latest OS. Before crashing i had android 10 with security patch update of June 01 2021.
    Now I need suggestion from expert here,
    1. Is there any way I can get the data back?
    2. How can I get the latest android version from my phone?
    3. Why did it went into "Qualcomm CrashDump Mode"?
    P.s. Screenshot of the setting and crashdump pic attached for the reference.
  2. Master_TC
    KitKat Jul 23, 2021
    Master_TC , Jul 23, 2021 :
    If you have not saved you data in the cloud or elsewhere, then your data is lost. You can't get them back
    The latest OOS can you download from the oneplus support page -> downloads
    You can install it manually.
  3. raisulbappy
    Hello there, I've tried it, but it's not allowing me to do that way. Getting this message,
  4. shwetanksinha
    Donut Jul 23, 2021
    shwetanksinha , Jul 23, 2021 :
    Hi buddy. I know how to do this. You need to manually download and install last update of each Android versions.
    I mean now you need to download and install last Android 8.1 update.
    Then the first android 9 update, then last Android 9 update
    Then first android 10 update, then you can install the latest software update through OTA.
    And you cannot retrieve your data.
    Also, I had the same issue. My device went to Qualcomm Crashdump Mode. I tried MSM tool several times, but didn't work... So, how did you do it?? What did you do after opening the back panel of the device. Please contact me-
    Removed by mod
    I have all the links you need. Please contact me. I also want to retrieve back my OnePlus. Please reply back😭
    raisulbappy likes this.
  5. BeingIncog
    Nougat Jul 23, 2021
    BeingIncog , Jul 23, 2021 :
    do not ever share your personal details on public forums.
    shwetanksinha and raisulbappy like this.
  6. pablofg1978
    Head Moderator Head Moderator Jul 23, 2021
    pablofg1978 , Jul 23, 2021 :
    Hello there,
    Please don't post personal information in public
  7. Master_TC
    KitKat Jul 23, 2021
    Oh yes you are on A8. You have to install always the first and the last version of A8 1 - A9 - A10
    Then you can install or get the latest A10 version.
    raisulbappy and BeingIncog like this.
  8. raisulbappy
    Hey there, thanks for the step by step process. I'll try it then.
    I've taken my phone to repair shop, and the hardware expert retrieve it. I'm sorry I don't know the process. He said it's a CPU failure issue.
  9. raisulbappy
    Thanks a lot for the info. I'll try it and share the update soon.
  10. raisulbappy
    Cupcake Jul 25, 2021
    raisulbappy , via OnePlus 6 , Jul 25, 2021 :
    Hello, Your suggestions worked. I've upgraded my phone to Android 11 open beta 1. 😊
