Op 8 pro - fingerprint scanner issue via OnePlus 8 Pro
  1. Swappyy
    Eclair Feb 28, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Feb 28, 2021
    Best Answer
  3. pablofg1978
    Head Moderator Head Moderator Feb 28, 2021
    pablofg1978 , Feb 28, 2021 :
    Then the ratio is 2/10....
    Do you use a screen protector?
    Arjun_Choudhry likes this.
  4. Swappyy
    Eclair Feb 28, 2021
  5. Dresa91
    Dresa91 , Feb 28, 2021 :
    What OxygenOS Version are you using?
    Did you clear cache in recovery?
    Did you disable unlock per fingerprint and re-enable it?
  6. Swappyy
    Eclair Feb 28, 2021
    Swappyy , via OnePlus 8 Pro , Feb 28, 2021 :
    I m using android 11.0.4.4 version.
    I disabled fingerprint lock for while.
  7. Dresa91
    Can you enable it now and test it?
    Can you test it in safe mode?
  8. Swappyy
    Eclair Feb 28, 2021
    How to clear cache for recovery
  9. Swappyy
    Eclair Feb 28, 2021
  10. Dresa91
    I did not wrote to do a factory reset.
    Do a clear cache in recovery. I gave you the link to a guide how to do it
  11. Does!Compute
    KitKat Feb 28, 2021
    Does!Compute , Feb 28, 2021 :
    Try enrolling your fingerprints in a completely dark room. The scanner is an optical scanner, and it learns better when there is no interference from other light sources.
    Dresa91 likes this.
  12. Swappyy
    Eclair Mar 2, 2021
    Dresa91 likes this.
  13. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Mar 2, 2021
    Dresa91 , Mar 2, 2021 :
    Great to hear:)
  14. Swappyy
    Eclair Mar 2, 2021
    Dresa91 likes this.
  15. Dresa91
    You are welcome:)
    okay:)
