8
OP clear case NOT recommed
  1. Hawaiian player
    Ice Cream Sandwich Aug 8, 2014
    Hawaiian player , Aug 8, 2014 :
    I received the OP clear case I order last week I was shock the quality of the case. is just a clear plastic is very thin and very flimsy. compare to the flip cover is look cheap and cost $10.99.I also bought the flip cover, but the flip cover is much nicer look very high end and cost $4.more than the case. if you are looking to buy the case I'm not recommend the clear case, I recommend buying flip cover is much better product
  2. J-Pan
    knuffi and Elas like this.
  3. prosperbananzi
    Eclair Aug 8, 2014
  4. Sidhar
    Jelly Bean Aug 8, 2014
    Sidhar , Aug 8, 2014 :
    Thanks for sharing this.
    Seddary likes this.
  5. Elas
    Elas , Aug 8, 2014 :
    this, and i never liked it anyway
  6. Seddary
    Honeycomb Aug 8, 2014
    Seddary , Aug 8, 2014 :
    Thanks for the info
  7. Min
    Eclair Aug 8, 2014
  8. Infotalk
    Eclair Nov 17, 2014
    Infotalk , Nov 17, 2014 :
    I ordered clear case by mistake in the pre-order today. I wish I had seen your post earlier.
    Is there a way to cancel just the clear case from the pre-order .. Someone, please help.
  9. Andril
    Honeycomb Nov 17, 2014
    Andril , Nov 17, 2014 :
    i paid for one as well and it lasted 3 minutes till my 1+1 popped out of it
  10. xKRYPTx
    Gingerbread Nov 17, 2014
    xKRYPTx , Nov 17, 2014 :
    On the pre-order confirmation page it said you will get an email before it ships with a chance to change your order...
    Oh and I ordered both the clear case and the flip. I figure most of the time I'll use the flip, and occasionally use the clear cover when its strictly pocket time for the phone..
  11. Infotalk
    Eclair Nov 17, 2014
    Is there a way to return it or cancel that clear case order ?
  12. Linanc7
    Lollipop Nov 17, 2014
    Linanc7 , Nov 17, 2014 :
    Flimsy like bendable? I have an OPO vase and agree there are much, much better options on the market, but its a hard plastic. Just curious
  13. M4ENY
    KitKat Nov 17, 2014
    M4ENY , Nov 17, 2014 :
    The colored cases are fine too
    My friend and I both ordered that and we are both satisfied with it
  14. Infotalk
    Eclair Nov 17, 2014
    I just says you will be able to make "address" modifications
  15. xKRYPTx
