OP2 - 3300 mAh Battery - Sufficient?
  1. anjan2683
    Honeycomb Jul 29, 2015
    #41
  2. finaldentiny
    Community Veteran Jul 29, 2015
    #42
  3. B4kken
    Lollipop Jul 29, 2015
    B4kken , Jul 29, 2015 :
    Before Lollipop I got 7(!) hours of screen time on my One with over 24 hours of usage/since last charge. KitKat was great and I'm hoping that Android M will be too. 10000 mAh seems like to much for comfort, but at the same time he'll get pretty good battery life on any rom...
    #43
  4. Petre
    Eclair Jul 29, 2015
    Petre , Jul 29, 2015 :
    Currently my phone has a 2100mAh Battery and is on an older CPU. It lasts about a day and a half. If the OnePlus two lasts 3 days on normal use, it is fine with me. I don't mind charging the phone every two-three days, especially considering I charge mine every night now :)
    But, I think manufacturers should start focusing on better batteries, not on higher screen resolutions or faster CPUs. We don't use half of the processing power that the phone has.
    #44
  5. swag_daddy
    Gingerbread Jul 29, 2015
    #45
  6. jonnyseven
    Eclair Jul 29, 2015
    jonnyseven , Jul 29, 2015 :
    I guess it depends if you're a prolific user or not. My usage varies usually the single charge is more than adequate for me on the opo with maybe 30 to 40% left at the end of the day. However I carry around an additional battery pack to recharge my phone should the need arise. If the standard battery could hold 5000mah without compromising on size I'd not bother with it.
    #46
  7. lostLambda
    #47
  8. sleepdragonone
    KitKat Jul 29, 2015
    sleepdragonone , Jul 29, 2015 :
    Will see, it should last for a day.
    #48
  9. Blueeye
    Ice Cream Sandwich Jul 29, 2015
    Blueeye , Jul 29, 2015 :
    I think it's about power management it is upon the apps I guess 1+ has worked upon this issue
    #49
  10. armmani2001
    KitKat Jul 29, 2015
    #50
  11. praviarva
    praviarva , Jul 29, 2015 :
    It should be good enough for a day (15 to 20 hours). You must buy a power-bank if you travel a lot or have a little time to charge. I have a Romoss 10000 and a Romoss 4000 mah power banks (I got it free with 10000) and they really do good.
    #51
  12. senegalas
    #52
  13. aditya2607
    Eclair Jul 29, 2015
    #53
  14. AriesATG
    AriesATG , Jul 29, 2015 :
    I asume it will have a fantastic battery life paired with the optimized screen and processor/software.
    We must see it irl
    #54
  15. mukun
    Froyo Jul 29, 2015
    #55
  16. molokovellocet9
    molokovellocet9 , Jul 29, 2015 :
    Performance will depend on how well they get the phone operating with Oxygen, apps and its processes.
    The battery should be fine provided they manage the otherel bits well.
    #56
  17. atiq.qasim.12
    atiq.qasim.12 , Jul 29, 2015 :
    I think OP2 Battery will be perfect for a daily one time charge basis.
    Charge at night and Use all Day.
    #57
  18. armmani2001
    KitKat Jul 29, 2015
    armmani2001 , Jul 29, 2015 :
    Should be more than enough! That 810 is very power hungry I guess.. Also it could be the finger print reader that uses a lot of battery as they mentioned its always ready to scan even when its in deep sleep!
    #58
  19. 12dollar
    Cupcake Jul 29, 2015
    12dollar , Jul 29, 2015 :
    it all depends on the screen. I hope they really came up with something great since the screen stayed the same in relation to size and dpi
    #59
  20. thomaslong
    thomaslong , Jul 29, 2015 :
    even though it still doesn't live as long as the OPO it still has a decent battery
    Source MKHBD OP2 first impressions
    #60
