OP2 Charging Time
  1. TimeFlies7
    Ice Cream Sandwich Jul 11, 2016
    TimeFlies7 , Jul 11, 2016 :
    Guys...What is ur OP2 average charging time? I think there's something wrong with mine :(
    It takes around 5-6 hours to fully charge. :(
  2. Jitesh Saitawadekar
    KitKat Jul 11, 2016
    Jitesh Saitawadekar , Jul 11, 2016 :
    I think it takes around 1hrs 30mins to 2hrs to fully charge from 0% to 100% i think you need to wipe cache from recovery see if it helps you.
    Adityaf likes this.
  3. TimeFlies7
    Ive reformatted... I thk i need to try other charger n cable...
  4. Adityaf
    Adityaf , Jul 11, 2016 :
    Just drain hole battery. And charge it 0--100%
    Repeat this for two times.
    Don't use phone while charging
    Jitesh Saitawadekar likes this.
  5. gamsurslick
    Honeycomb Jul 11, 2016
  6. itssandeepd
    itssandeepd , Jul 11, 2016 :
    sometimes it happens with mine too. my cable got damaged, i cannot use it for data transfer anymore and sometimes it shows 5-6 hours to fully charge. when ever i unplug cable on both sides(device and power brick) and plug it again it works fine. may be it will work for you too,
  7. lewisrolls
    Cupcake Jul 12, 2016
    lewisrolls , Jul 12, 2016 :
    I'm having the same problem with my OP2. The home button broke 1 month after using it, is a hindrance but I put up with it. The charging time for me today from 70% to 100% has given an estimate of 9 hours to full charge. Not sure if it's to do with the new software being buggy or not or whether it is my charging cable. (Only had OP2 for 7 months).
  8. F_Vivek_Patil_NTai
    F_Vivek_Patil_NTai , Jul 12, 2016 :
    My op2 battery showing 8 hrs to fully charge,took 23 mins to charge 2% to 10%
    I have cleared cache & also upgraded to marshmallow, using the same oneplus cable & adapter
    It's showing 210mA to 610mA charge rate,
    Kindly suggest any solutions
    Need help !!
  9. rahmannek
    Honeycomb Jul 12, 2016
    rahmannek , Jul 12, 2016 :
    change or try with new charger cable, i'm having the same problem with original OP cable. before its take 6 to 8 hrs. i changed cable and now its work fine as before
  10. gnatale
    Eclair Jul 13, 2016
  11. Manas Eapen
    Jelly Bean Jul 13, 2016
  12. F_Vivek_Patil_NTai
    Cupcake Jul 13, 2016
    F_Vivek_Patil_NTai , Jul 13, 2016 :
    Any links were you bought the cable,
    Or particular brands..??
    Suggest me.
  13. F_Vivek_Patil_NTai
  14. F_Vivek_Patil_NTai
    Which cable did you buy..?
    Brand?
  15. Manas Eapen
    Jelly Bean Jul 14, 2016
    Manas Eapen , Jul 14, 2016 :
    I bought the dash compliant cable from oneplus with the view for an upgrade to oneplus 3. But I would suggest you go for a good quality( that supports quick charging (2.4amp)) micro USB cable plus a xiaomi / oneplus type c adapter since that would come in handy for your other devices as well
  16. kotadheeraj
    Eclair Jul 14, 2016
    kotadheeraj , Jul 14, 2016 :
    Even I also facing the same problem can you help me guys I don't know what's the problem... If I use the OP3 cable to OP2 will anything happens to the battery?
  17. rahmannek
    Honeycomb Jul 15, 2016
    rahmannek , Jul 15, 2016 :
  18. Hazieq_Zulnwr
    Donut Jul 15, 2016
    Hazieq_Zulnwr , Jul 15, 2016 :
    I also face the same issue. It's because of the cable. I've change my cable to the new one, and it's work normal. I don't know why, but a lot of op2 user face the same problem after the MM update.
  19. BrainsCollector
    Honeycomb Jul 18, 2016
  20. Georgevs
    Gingerbread Jul 18, 2016
    Georgevs , Jul 18, 2016 :
    I have the same problem, from 13% to 100% it took 4 hours. The problem appeared a month ago or so, before in two hours it was full. I noticed that every time I turn the USB cable (in the charger) from one side to another it works better but for a little while. I have open a ticket to oneplus, they requested my phone so they can check it. The problem is that I need the phone.
