31
#OP2 found Technical glitches in 2 important features.
  1. john3293
    Jelly Bean Oct 19, 2015
    #61
  2. Bharath HT
    KitKat Oct 19, 2015
    Bharath HT , Oct 19, 2015 :
    I
    I have a small issue and need help if anyone else came across this and got resolved... Everytime I swipe down the notification panel it stutters to come down rather than a smooth flow down and the same thing happens when I open a contact for the first time after sometime...
    #62
  3. hk43789
    Honeycomb Oct 20, 2015
    #63
  4. praveenpancharia
    Cupcake Oct 27, 2015
    praveenpancharia , Oct 27, 2015 :
    I am also facing the same problem. Lets say if I am using SIM1 for back-to-back calls (I have set-up to "Ask me every time" in Calls SIM settings), after few calls it changes to SIM1 in settings also and stop giving me option to choose SIM card for calls.
    Please let me know if there is any fix or work around for that.
    #64
  5. deepakgopalsharma
    Cupcake Nov 2, 2015
    deepakgopalsharma , Nov 2, 2015 :
    I am also facing the same issue, this is not related to hardware, a patch can fix it. Hope we will get the fix soon.
    #65
  6. bill33021
    Cupcake Nov 3, 2015
    bill33021 , Nov 3, 2015 :
    I am looking to buy and OP2 for the dual sim feature. I want to buy a sim in France for my visits there and my ATT sim for the US. Can I do this on the OP2?
    #66
  7. keegiteine
    Cupcake Nov 6, 2015
    keegiteine , Nov 6, 2015 :
    Has anyone found any solution/updates on the matter? This is really annoying! How come this is not solved yet?
    #67
  8. spooke
    Honeycomb Nov 6, 2015
    spooke , Nov 6, 2015 :
    This annoys the hell out of me, I normally swap data over to my work sim when I'm away on site and the fact that the phone freezes for 30 seconds gets really annoying, especially when I tend to use the sim which has the best signal at the time...
    #68
  9. Crononaut
    Cupcake Nov 9, 2015
    Crononaut , Nov 9, 2015 :
    I have also experienced the problem sometimes when i move out of range of a WiFi network I have just been on. It refuses to go on-line, and when I check the data settings. Cellular data is disabled on both SIMS.
    #69
  10. pranav1234
    Gingerbread Nov 16, 2015
    #70
  11. deepakgopalsharma
    Cupcake Nov 17, 2015
    deepakgopalsharma , Nov 17, 2015 :
    Yesterday, I got an update for my one plus 2, after which the sim selection issue while making call is resolved. Thanks to One Plus team.
    #71
  12. kamlesh_OnePlus2
    Eclair Nov 17, 2015
    #72
  13. Chika
    Ice Cream Sandwich Nov 17, 2015
    Chika , Nov 17, 2015 :
    OTA update 2.1.2 resolved these issues. Enjoy
    #73
    Dan_Badaluta likes this.
  14. Sarzil
    Eclair Nov 17, 2015
    Sarzil , Nov 17, 2015 :
    That is true I have faced similar issues,I have stopped using 2 sims now.. bit disappointed with it, In my OP2 at one point I could not make any calls from the phone, I had to remove second sim.It was too much hassle two get both sim working correctly as expected.There is a bug in the OS it needs fixing.
    #74
  15. derickeeeee
    Gingerbread Nov 18, 2015
    derickeeeee , Nov 18, 2015 :
    I've already received the Ota 2.1.2 but the issue still persists. The cellular data function is still focused only on sim 1. I can't swiftly switch cellular data networks.... If it's fixed then how do I go about it.
    #75
  16. Sinnaz0709
    Ice Cream Sandwich Nov 19, 2015
    Sinnaz0709 , Nov 19, 2015 :
    I can't seem to set my calls from ask everytime to one sim it switches back to ask every time. Due To vehicle Bluetooth I would like to switch calls from ask everytime to one sim but it's not working or its a bug can some one help?
    #76
  17. coolbeet
    Donut Nov 19, 2015
    coolbeet , Nov 19, 2015 :
    also, everytime i want to pull down notification center, it stucked in half way...
    #77
  18. supraket
    Gingerbread Nov 19, 2015
    supraket , Nov 19, 2015 :
    Hi
    I just got OP2 2 days back. And the moment I started it had an OTA update.
    I don't think the problem exists anymore, does it? I still have to explore on mine that.
    Though I do find another issue with Messenger (Text Message App). I can't seem to delete multiple messages from a particular sender. On my other Android devices, if I had to delete few messages (and not all) in the conversation thread, all I had to do was long press on one message and then single tap on other messages I had to delete. However it seems to have gone now and the only thing I can do is delete complete conversation, which am not keen on.
    Anyone has any solution for this?
    #78
  19. kamlesh_OnePlus2
    Eclair Nov 20, 2015
    kamlesh_OnePlus2 , Nov 20, 2015 :
    Facing new issue in 2.1.2 :(
    Setting >> SIM cards >> Preferred SIM for Call or SMS
    Whenever i select any SIM say sim1 or sim2 as preferred sim for call or SMS even then also OP2 shows pop up asking sim preference while dialing. After this setting when i tried to look in to same setting to my surprise it shows "Ask Every time" as selected preference. NO matter how many times i have selected sim1 or sim2 as preferred sim but it shows "Ask Every Time" always...
    #79
    AndyStubbs likes this.
  20. Niyasummar
    Cupcake Nov 20, 2015
    Niyasummar , Nov 20, 2015 :
    Let's see if any of you seen this issue before !
    Disable sim 1 > open phone > take recent calls > try calling someone using the sim 2
    My phone straight away crashes and reboots !
    #80
