26
OP2 has overheat issues or not? The first temperature test is here!
  1. breaklumia920
    Eclair Jul 30, 2015
    breaklumia920 , Jul 30, 2015 :
    Here are the summary of OP2 temperature test (all in CELSIUS):
    • basic usage: max 34 degrees
    • web browsing: max 44 degrees
    • application running: max 43.7 degrees
    • hardcore usage: max 45.6 degrees
    read more on english source: http://gsminsider.com/2015/07/onepl...-test-overheat-test-reveals-up-to-45-degrees/
    However, still NOT as hot as One M9. Colder than HTC One M9
    read more on english source: http://gsminsider.com/2015/07/snapdragon-810-temperature-tests-oneplus-2-vs-htc-one-m9/
  2. Sergi.24
    Froyo Jul 30, 2015
  3. xavier1782
    Ice Cream Sandwich Jul 30, 2015
    xavier1782 , Jul 30, 2015 :
    Yea I'm afraid if I get it soon after the launch n then what If it has a heating problem..hmm
  4. Karkan
    Gingerbread Jul 30, 2015
  5. breaklumia920
    Eclair Jul 30, 2015
  6. Harryson
    Eclair Jul 30, 2015
  7. Farazahmed7
  8. Joost1985
    Joost1985 , Jul 30, 2015 :
    These are probably desk tempratures. I'am wondering about the pocket tempratures :) we will see shortly
  9. Waelt
    Honeycomb Jul 30, 2015
  10. alphaplus
    gowthamgam likes this.
  11. breaklumia920
    Eclair Jul 30, 2015
    V2.1 is better than the older version of S810
    sagar452 likes this.
  12. duy_86
  13. NobodyE
  14. parsa5
    Jelly Bean Jul 30, 2015
    parsa5 , Jul 30, 2015 :
    There is no older version of the 810.... every 810 device has the version 2.1.
    Methiri, Jeffrey98, bp328i and 4 others like this.
  15. Karkan
  16. shrenil19
    shrenil19 , Jul 30, 2015 :
    You might add that's in celcius
  17. imattv4
    imattv4 , Jul 30, 2015 :
    45°c is absolutely warm.
    My nexus 5 would get to like 70°c with light gaming, so I will definitely be fine with any slight heat from the op2
    sagar452, evil11204 and rphlfjrd like this.
  18. pbergonzi
    KitKat Jul 30, 2015
    pbergonzi , Jul 30, 2015 :
    Thank you for stating that--I had to google it, and it was illuminating.
    parsa5 likes this.
  19. FaizAnsari
    FaizAnsari , Jul 30, 2015 :
    Well HTC said that the HTC M9 houses the newer version of Snapdragon 810 which is v2.1 so i think Oneplus 2 is not heating much as it is underclocked.
  20. magnamentis
    magnamentis , Jul 30, 2015 :
    thanks for the useful info!
    I just checked my ONE, 45C CPU temp after hours of idle and just installing a kernel tweaking app. battery 29C. CPU went down to 39 after a minute screen on doing nothing, room temp 28C, outside temp 42C ( just as a side note LOL
    kraasz likes this.
