26
OP2 has overheat issues or not? The first temperature test is here!
  1. kumarp200
    Cupcake Nov 9, 2015
    kumarp200 , Nov 9, 2015 :
    My Oneplus Two sometimes reaches 51 degree. Should I get it replaced? I checked the temp using CPU-Z app. Also there are some kernel tweaking apps in market, should we try them.
  2. elanglois
    Lollipop Nov 9, 2015
    elanglois , Nov 9, 2015 :
    You should say how this was tested. Its not accurate if not testing in real time with an overlay. By the time you switch apps to look at temp, its dropped. Use CpuTemp and it's overlay function.
    My OPO will bounce off the thermal throttle with prolonged hardcore cardboard since it never gets a chance to cool down. Observed 76C
  3. elanglois
    You must hate your phone. Heat doesn't hurt it nearly as much as the sudden change in temp. Next time just turn it off and let it cool.
  4. elanglois
    That isn't hot. And it has a built in throttle to protect itself (set at 75C).
  5. kumarp200
    Cupcake Nov 9, 2015
    The upper RIM gets so hot that it feels on skin while talking, it got me really worried.
  6. demongokul
    Ice Cream Sandwich Nov 9, 2015
    demongokul , Nov 9, 2015 :
    Yea the phone doesn't heat up as other phones. I don't know why people spam the forum saying its heating.
  7. destutt
    Froyo Nov 9, 2015
    destutt , Nov 9, 2015 :
    Is that normal?because for me it is NOT NORMAL
  8. destutt
    Froyo Nov 9, 2015
    Spam?how many phones have you got?I have had quite a few and this phone's heat is abnormal.OnePlus one did not have such problems and I am a proud owner of a 1+1.people don't complain for the sake of complaining ok?
  9. elanglois
    That's cause the rim is a heat sink. Better out than in
  10. elanglois
    Incorrect. Post real numbers and you'll see the OPO is hotter. The difference is the OPO keeps it inside while the heat sink on the OPT transfers it to your hand
  11. elanglois
    Yes, that is way COOLER than normal
  12. imattv4
    Ice Cream Sandwich Nov 10, 2015
    imattv4 , Nov 10, 2015 :
    It isnt a drastic temp change.
  13. diper08
    Cupcake Nov 10, 2015
  14. elanglois
    Lollipop Nov 10, 2015
    elanglois , Nov 10, 2015 :
    Icing it down? LOL.
    Anyone reading .... if somehow your phone hits 90+C (throttle temp is 75 so thid should never happen), I strongly suggest you hit the power button and set it down. Do NOT ice it down!
