OP2 overheating
  1. F_Abraham_Arrearan_KXlh Cupcake Mar 20, 2017
    F_Abraham_Arrearan_KXlh, Mar 20, 2017 :
    I have several problems with my mobile, I attach some pictures of this, is this normal?
    Also the battery take a lot of time to be at 100 (6-8hrs)
    What can I do to fix it?
  2. Kokaneamol Cupcake Mar 21, 2017
    Kokaneamol, Mar 21, 2017 :
    since op2s 3.5.6 my phone is heating a lot and battery drainage is also like hell. I have even reduced number of apps after update thinking that might help, but no use.
    I'm feeling to fall back to old version, as the previous version didn't heat this much. now a days my device's normal temperature is 40.9 degrees. That's the only reason I'm waiting for an update, be it N or any ota to solve it.
    And if op has no future plans for such ota release, then I will do it soon. let me know if you have any solution for over heating.
  3. SaketGillurkar Honeycomb Mar 21, 2017
    SaketGillurkar, Mar 21, 2017 :
    same issue...heatup lot and start lagging...Whike playing games also its get lags Battery draining lot!!
  4. G_Julius_Verne_JnoR Gingerbread Mar 21, 2017
    shayanzahedana likes this.
  5. shayanzahedana Froyo Mar 21, 2017
    shayanzahedana, Mar 21, 2017 :
    same untill I got lineageOS!
  6. Shubham Pahwa Gingerbread Mar 21, 2017
    Shubham Pahwa, Mar 21, 2017 :
    To solve heating issue:
    Go to Settings> Battery> menu> High power usage apps. See which app is consuming more power. If no apps show up download Greenify and hibernate continuous running apps. It will reduce device heating and also extend battery.
    Sometimes the reason behind phone's heating is poor ventilation due to tight case. Lithium ion batteries drain fastly under heated condition which is bad for both phone and battery. So see if the problem is solved by just taking off phone's case.
  7. Kirakichi Jelly Bean Mar 21, 2017
    Kirakichi, Mar 21, 2017 :
    Luckily OP3/3T is polymer, yet alot of people think it is ion and during review they say its ion, so when i see it saying "ion" im sure they havent reviewed phone professionally, so i skip those gimpsy fancy gimmick-alike reviews.
    No need to waste time on sh*t reviews if even the reviewer has no idea what he's reviewing after.
    Back to the OP's issue, switch back or get Lineage OS, don't expect OP to push update, it will be unannounced OTA if there is any scheduled.
