OP2 SOT is Very Poor - Need to know if its a HW issue
  1. charanchakravarthi
    Honeycomb Dec 17, 2015
    charanchakravarthi , Dec 17, 2015 :
    OP2 SOT is Very Poor - Need to know if its a HW issue. I have been using OP2 for about 2-3 months now and recently the SOT is very poor, I think something is screwed on the HW side. I have wifi, bluetooth, LTE, location turned on all the time. But that has been the case always. I have cleared cache and charged from dead to full with the phone turned off, nothing helps.
    I know there are few threads that show the battery life on 2.1.2 is pretty bad, but this is worse. So I have very little confidence that this is from a SW problem.
    Please advice..
  2. Tobikage
    General Support Expert Award 2021 Dec 17, 2015
    Tobikage , Dec 17, 2015 :
    Advice ??
    Post some Screenshots of the battery stats :rolleyes::rolleyes:
    The NSA sends it's regards :rolleyes:
  3. charanchakravarthi
    I thought everyone does that..!! :eek::eek:
  4. camohan
    Assistant Head Moderator Assistant Head Moderator Dec 17, 2015
    camohan , Dec 17, 2015 :
    The screenshot is not enuf, show battery graph which apps consumes how much you see..!!!
    Which ROM are you on rooted/ not rooted...!!!
    otto2 and Tobikage like this.
  5. Tobikage
    Post the graph too.
    How much standby time ?
    That SOT is crappy BTW.
    Linanc7 and Deepak.Si like this.
  6. charanchakravarthi
    I have updated the screenshots.. Perhaps this would help, It is surprising to see NFS with highest usage, it will usually be the screen and android OS. May be because of my gaming last night and I forgot to close the NFS application.
  7. charanchakravarthi
    Im on stock.. Not rooted.
  8. charanchakravarthi
    Its all about misdirection.... :D;)
    Tobikage likes this.
  9. Tobikage
    See the problem ??
    Find out what's keeping your phone awake.
    I get an average 3.5hrs SOT with WiFi on all day using Dual SIM's on the latest stock ROM update.
    No root or tweaks.
    Baymax, nyzproof333 and Deepak.Si like this.
  10. Eshan_Anand
    Ice Cream Sandwich Dec 17, 2015
    Eshan_Anand , Dec 17, 2015 :
    your phone is always awake and doesnt go into deep sleep even when screen is off, this is a software issue, lookout for the app causing you this trouble
  11. charanchakravarthi
    3.5 Hrs of SOT seems good compared to my situation. However I do not have any applications open like I did yesterday, the battery consuming apps for me were usually Screen and Android OS most of the time. I am not sure how to control that, may be I should not touch the phone?? :confused::confused::confused:
    I keep checking something all the time, my phone is always in my hand and I keep doing something with it. I should refrain from doing so ??:eek::eek::eek:
  12. charanchakravarthi
    Thanks for the insight, do you know which of the apps can do that ? because when I check the battery life and the applications that consume more juice, its the screen and Android OS, that is consistent.
  13. charanchakravarthi
    Updated some screenshots of background processes. FB tops the list.. No surprise though..
  14. Tobikage
    FB and Play services usually compete over who can drain the most battery. :rolleyes:
    Clear cache from recovery , Charge to a 100% , Use the phone over an extended period of 8 or 10 hrs and then check the stats.
    otto2 and Deepak.Si like this.
  15. Eshan_Anand
    use 'wakelock detector' app
    keessonnema likes this.
  16. ngaunguyens
    ngaunguyens , Dec 17, 2015 :
    I think uhh you should do a factory reset on your phone if you havent done that. See if the problem still persisted. If it is still, you should try and flash boeffla kernel :) it has a good battery life!
  17. faustoandrevdyo
    Gingerbread Dec 17, 2015
    ngaunguyens likes this.
  18. ngaunguyens
    Some time i dont trust system update, it could still leave some stupid behind... Idk if this is true or not, but it seems like it when I customly flash roms to update froma version to version. So I have been flashing the full stock rom rather than the small updates on my phone. And it does make a difference for battery life lol
  19. ngaunguyens
    You can tweak even more to get an hr or 2 more!
  20. faustoandrevdyo
    faustoandrevdyo , Dec 17, 2015 :
    How? It would be really really awesome!!!
