Op2 sync with car bluetooth
  1. 591994
    Eclair Sep 11, 2015
    591994 , Sep 11, 2015 :
    My op2 is not able to sync contacts with hyundai elite i20 Bluetooth . Moto g with lollipop was able to . any suggestions???
  2. Deactivated User
    Sep 11, 2015
    Gavin McAnally likes this.
  3. Deactivated User
    Sep 11, 2015
  4. 591994
    Eclair Sep 11, 2015
  5. Deactivated User
    Sep 11, 2015
    nathanluxford and 591994 like this.
  6. cpt.ogger
    Cupcake Sep 11, 2015
    cpt.ogger , Sep 11, 2015 :
    Hey,
    i have the same problem with my insignia and the DVD800. Phonebook shows only one contact, and this is my own ....
    So 'll try the phonebook app later today.
    THX and GRTNX
  7. cpt.ogger
    Cupcake Sep 13, 2015
  8. vivaespana209
    Cupcake Sep 16, 2015
    vivaespana209 , Sep 16, 2015 :
    Hi there, sorry what's the process for using this Bluetooth Contacts app. I have paired my OPT with my new Seat and installed app but still will not import contacts. Thanks for any help in advance
  9. sameekhan
    Donut Sep 18, 2015
    sameekhan , Sep 18, 2015 :
    Having same contact sync issue with my Grand i10 Automatic. Never had Issues with Moto X (2nd Gen), Moto G3, Meizu M2 Note, Samsung S6 Edge and even Windows phones.
    But OnePlus 2 is not syncing any contact and kept failing to do it.
    I think OnePlus team should look into this because why we need a third party app to do this kind of simple work?
    akjain412 and veryannoyingname like this.
  10. SadButTrue
    Ice Cream Sandwich Sep 19, 2015
    SadButTrue , Sep 19, 2015 :
    also having the same sync problems with my Opel (Vauxhal) Mokka - with my OPO everything works great ;(
  11. Gavin McAnally
    Gingerbread Sep 19, 2015
  12. veryannoyingname
    veryannoyingname , Sep 19, 2015 :
    used the report button for this thread so that it alerts the mods to pass on the information about the third party app sorting the problem. Hopefully the oxygen OG devs can do the same in the next software update so that this sort of issue doesnt occur after next software update.
  13. prasams
    Donut Sep 22, 2015
    nathanluxford likes this.
  14. vivaespana209
    Cupcake Sep 22, 2015
    vivaespana209 , Sep 22, 2015 :
    For Seat León FR got it working by using the Bluetooth Contacts app and resetting the cars software to factory settings. Finally sorted, thanks for the advice!
  15. bonello77
    Honeycomb Sep 22, 2015
    bonello77 , Sep 22, 2015 :
    The same with peugeot 508...the sync of contact make the car software crash...
  16. jcespi2005
    Ice Cream Sandwich Sep 23, 2015
  17. donsimp
    Cupcake Sep 23, 2015
    donsimp , Sep 23, 2015 :
    Anyone having problems with connecting other bluetooth devices? My OPT can't find my plantronics Headset and jaybird bluebuds.
  18. jcespi2005
    jcespi2005 , Sep 23, 2015 :
    Tested OP2 with:
    1. BT headset Sony, working fine, no problem...
    2. Creative Sound Blaster Roar, working fine.
    3. Peugeot 5008 BT handsfree profile (with contacts sync), and no problems so far, working fine.
  19. difficult
    Honeycomb Sep 23, 2015
    difficult , Sep 23, 2015 :
    Buy a Moto G.....
  20. Rubinho10
    Rubinho10 , Sep 23, 2015 :
    It works great on my car (Range Rover Evoque 2.2). Try to disconect and connect the phone again.
    IvanMuse likes this.
