421
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. manitsolanki
    Cupcake Feb 16, 2018
  2. manitsolanki
  3. Yannis Neris
    Ice Cream Sandwich Feb 16, 2018
    Yannis Neris , Feb 16, 2018 :
    Don't need root..
    You need to unlock the bootloader and install custom recovery ( twrp )
  4. aashish16me
    Eclair Feb 16, 2018
    aashish16me , Feb 16, 2018 :
    Guys ik many of you'll are facing this battery issue with the op3t. Comment if you have any solution to this
  5. shiv1g
    Honeycomb Feb 16, 2018
  6. Sun90
    Starting Point Expert Feb 16, 2018
    Sun90 , Feb 16, 2018 :
    Check the pinned battery threads.
    There are comments in abundance.
    Also some useful remidies.
  7. RASTAVIPER
    Jelly Bean Feb 16, 2018
    RASTAVIPER , Feb 16, 2018 :
    I always enjoy dramatic titles.
    So what should we see exactly??
    No much use of the phone and no battery graph to check the draining.
    Nothing to comment.
  8. youbi
    Portuguese POC Assistant Head Moderator Feb 16, 2018
    youbi , Feb 16, 2018 :
    Threads merged. Please read the first post for some nice advices about the battery.
    Sun90 likes this.
  9. satyam_pandey
  10. Ansarirj
    Froyo Feb 16, 2018
    Ansarirj , Feb 16, 2018 :
    the first step i follow is clearing cache from recovery .. this seems to fix almost all problems .. i hope that would help with your camera issue
  11. 29071994
    Donut Feb 17, 2018
  12. G1518359413455
    Cupcake Feb 17, 2018
  13. Szöllösi Attila
    Donut Feb 17, 2018
  14. Yashrafa
    Gingerbread Feb 17, 2018
    Yashrafa , Feb 17, 2018 :
    Also had the battery issue but cleared cache and factory reset, now getting around 6-7 hrs sot
    If you want the issue to be resolved, bug reporting is the most easy way to get your thoughts across to the developers.
    link to the bug reporting/ feedback section:
    https://forums.oneplus.net/feedback/
    Submit a bug report with logs in the section.
  15. RASTAVIPER
    Jelly Bean Feb 18, 2018
    ArmataReloaded likes this.
  16. G_Parallax_MhUP
    Honeycomb Feb 18, 2018
    G_Parallax_MhUP , Feb 18, 2018 :
    dude...
    u use almost 20% of WhatsApp and 11% play store. what would you expect ?
    do you want 7 hours SOT like some people says ? u can't , cuz every people have their own type of usage.
    Mine got 5 and a half hrs sot. and that's my usage. sometimes i got only 3 hours. and it's normal
    stop complaining about "Battery Drain"
    and please use the search function *********
  17. BobbyV8_
    The Showcase Reviewer Feb 18, 2018
  18. HARVEY.SPECTER
    Gingerbread Feb 18, 2018
    HARVEY.SPECTER , Feb 18, 2018 :
    I too tried everything but my SOT still remains 4hrs, only one way is there to increase SOT that's rooting. and if you have SOT more than 4hrs without root,you're one of the lucky people on earth.
  19. OALEXANDER
    Indian POC Assistant Head Moderator Feb 18, 2018
  20. manitsolanki
    Cupcake Feb 19, 2018
    manitsolanki , Feb 19, 2018 :
    Those who are facing batter drain can turn off adaptive brightness. It worked for me and now getting almost 4-5 hrs SOT. Hope this helps for you all.
    Thank me later[e]1f44d[/e]
