421
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. pablofg1978
    Spanish POC Assistant Head Moderator Jun 27, 2018
    pablofg1978 , Jun 27, 2018 :
    Thread merged
  2. Oscarheresp
    Donut Jun 29, 2018
    Oscarheresp , Jun 29, 2018 :
    My OnePlus 3 has started to increasingly overheat since a month, until it has reached the point where I can no longer have a voice call without speakers when it overheats.
    It is just the upper half of the phone that gets too hot, with the hottest spot near the front camera.
    Does anyone know anything about this problem?
    bharath8055 likes this.
  3. G_BLaCK_JDbS
    Froyo Jun 29, 2018
    G_BLaCK_JDbS , Jun 29, 2018 :
    Mine does the same thing too
    maybe the cpu or the gpu is somewhere there and gets really hot?
  4. Oscarheresp
    Donut Jun 29, 2018
    That's what I thought, it still shouldn't be happening in a phone when it is not being used, I accept that it overheats when I have long video calls or when I'm on YouTube for a long time.
    f00tbaLL and bharath8055 like this.
  5. elanglois
    Lollipop Jun 29, 2018
    elanglois , Jun 29, 2018 :
    Sounds like a CPU core getting stuck. Does your developer mode have a CPU overlay? You want to see if one of the cores stays at Max
    f00tbaLL likes this.
  6. pablofg1978
    Spanish POC Assistant Head Moderator Jun 29, 2018
    pablofg1978 , Jun 29, 2018 :
    Thread merged
    Oscarheresp likes this.
  7. F_Syed_Shafin_gcmw
    Cupcake Jul 1, 2018
    F_Syed_Shafin_gcmw , Jul 1, 2018 :
    My phone gets wayyy too hot when I play pubg or watch any video, should I change my battery? It's been 1 year I am using the 3t
  8. ArmataReloaded
    Jelly Bean Jul 1, 2018
    ArmataReloaded , Jul 1, 2018 :
    What exactly means way to hot? If you want somebody to help you then we need more informations.
    How hot is your ambient temperature? Are you playing PUBG while charging? Which degrees are you reaching?
    F_Syed_Shafin_gcmw likes this.
  9. pablofg1978
    Spanish POC Assistant Head Moderator Jul 1, 2018
    pablofg1978 , Jul 1, 2018 :
    Merged
  10. F_Syed_Shafin_gcmw
    Cupcake Jul 1, 2018
    I don't play PUBG while charging and I haven't measured the temperature but it gets soo hot that you can't keep touching the screen for too long.
  11. F_Syed_Shafin_gcmw
    Cupcake Jul 1, 2018
    same with me
  12. chrisbin
    Cupcake Jul 2, 2018
  13. f00tbaLL
    Gingerbread Jul 2, 2018
    f00tbaLL , Jul 2, 2018 :
    Anyone here taken the plunge and renewed the battery and if so is it like it was when new or with all the upgrades to the software does the battery last longer now?
  14. paiktaras
    Donut Jul 14, 2018
    paiktaras , Jul 14, 2018 :
    Where is this option ?
    edit
    i found this....
    Αfter enabling this option in all installed applications you select ΄΄optimization΄΄ ?
    chrisbin likes this.
  15. Sandeep Kaushik
    Donut Jul 14, 2018
  16. N1509159450745
    Eclair Jul 18, 2018
    jagadabhi.varma likes this.
  17. Nezumi_
    KitKat Jul 18, 2018
    xnutzii, 223456dukjum and Iuliskaya like this.
  18. swvinod
    Gingerbread Jul 18, 2018
    swvinod , Jul 18, 2018 :
    You will need to have the game settings to the minimum in all aspects. but it would not help in effective gaming experience. even in minimum settings if its hot then the time u play need to be less. again its not what you would want as a gamer.
    223456dukjum likes this.
  19. N1509159450745
    Eclair Jul 18, 2018
    N1509159450745 , Jul 18, 2018 :
    hello boss, dont simply say like that, im playing in minimum setting, low grapic settings, i havnt start playing just for 10mints.. within 10mints it go heat up... should i play less minutes in the sense can i play for 1 minte... wat logic u telling... if u know something technical stuffs, help me....
  20. the98kid
    Ice Cream Sandwich Jul 18, 2018
    the98kid , Jul 18, 2018 :
    i think there must be a pinned thread in OnePlus 3/t section about battery/heating stuff. check that out.
