423
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. Z1545409872580
    Cupcake Dec 21, 2018
    Z1545409872580 , Dec 21, 2018 :
    why would you recommend to turn on aggressive doze , both doze should be turned off.. and keep all apps optimized
  2. Paschfire
    KitKat Dec 22, 2018
    Paschfire , Dec 22, 2018 :
    If you read the post you quoted, it doesn't recommend turning on aggressive doze aka advanced optimisation. So not sure what your point is.
  3. X1529500569718
    Cupcake Jan 3, 2019
    X1529500569718 , Jan 3, 2019 :
    Battery drains faster and device heats up a lot after December Security Patch. Does anyone have this problem? Please help. Thanks in advance.
  4. MrHari_theCarguy
    Jelly Bean Jan 3, 2019
  5. X1529500569718
    Cupcake Jan 3, 2019
    I'll post the results soon. Thank you for your response.
    MrHari_theCarguy likes this.
  6. F_Kundan_Hamies_gFJq
    Cupcake Jan 12, 2019
  7. F_Kundan_Hamies_gFJq
  8. G_Shashank_Sahu_tqUm
    Cupcake Jan 20, 2019
  9. Cervantes
    Lollipop Moderator Jan 20, 2019
    Cervantes , Jan 20, 2019 :
    Hi
    Please read the first post
    Thread merged
  10. G_Ahmad_Alsanousy_xwrb
    Donut Feb 4, 2019
  11. G_siva_sankar_gQDn
    Cupcake Mar 3, 2019
    G_siva_sankar_gQDn , Mar 3, 2019 :
    Frequently getting a notification as "Google is draining your Battery"and the battery is also draining soon. The phone is also getting heated up.
    And while charging also the phone is getting heated up. It's really very hot. Feeling like it would burst.
    Suggestions pls.
  12. Heramb Hindurao
    Cupcake Mar 18, 2019
    Heramb Hindurao , Mar 18, 2019 :
    I have been using my one plus 3 device since it was launched I did not face any issue with the device but from the past month or so my phone is continuously getting hang and heating at regular intervals anyone can suggest any help ..??
  13. Nishit kedia
    Nishit kedia , Mar 18, 2019 :
    from the past 2-3 days, the charging of my phone is deteriorating very quickly and the phone turns off automatically when put on charge. moreover, The phone turns off when at 10% and shows low battery warning .
    is there a problem with my battery or it's my charger?
  14. Cervantes
    Lollipop Moderator Mar 18, 2019
    Cervantes , Mar 18, 2019 :
    Hi
    The battery thread is a thread of questions and/or commentary
    Please, read the first post
    Thread merged
  15. U1548758712150
    Donut Mar 21, 2019
    Federico Pichler likes this.
  16. ghostofcain
    Marshmallow Mar 21, 2019
    ghostofcain , Mar 21, 2019 :
    Yes, and? It's called thermodynamics, you work a processor hard and it generates heat.
  17. G_siva_sankar_gQDn
    Cupcake Apr 3, 2019
  18. Amardeep_08
    Donut Jun 20, 2019
  19. Egor_Mikituk
    Cupcake Jun 25, 2019
    Egor_Mikituk , Jun 25, 2019 :
    Guys, please could you say which battery I should use to replace the old one? It is hard to find which is recommended. (
  20. Nerdis
    Froyo Jun 25, 2019
    Nerdis , Jun 25, 2019 :
    let OnePlus replace it for you
