423
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. G_Denis_Malyavin_ZQuR
    Cupcake May 31, 2017
    G_Denis_Malyavin_ZQuR , May 31, 2017 :
    re Facebook drain, looks like they have recently released lite versions of both the core app and the messanger, wonder if they eat less power now
  2. rahulsharan1984
  3. hortond
    Donut May 31, 2017
    hortond , May 31, 2017 :
    hi i have this battery draining problem since day 1. but ever since i disable proximity wake feature under the display settings. no more battery draining problem. can you please confirm this? im on oos 4.1.3 and nougat 7.1.1
    seems to work. im on my 3rd day now. battery is so so damn good. lasts for around 16hours at normal usage at wifi always on. and no more draining during overnight.
  4. Android450
    Marshmallow May 31, 2017
    Sun90, varma246, adpro and 2 others like this.
  5. Android450
    Android450 , May 31, 2017 :
    WhatsApp, Messenger lite, and signal
    Sun90, varma246, adpro and 1 other person like this.
  6. peaky blinders
    Jelly Bean May 31, 2017
    peaky blinders , May 31, 2017 :
    I find doze & aggressive doze work well. Overnight when sleeping with WiFi turned on I lose 2-3% battery.
    Some people don't recommend this but I swear by greenify app.
    Android450 and Dresa91 like this.
  7. Android450
    I turned that off because I didn't use it, never checked if it made any difference
    Sun90 likes this.
  8. Android450
    I tried it I found some improvement but I don't really use it, others can though if they feel they should
    Sun90 and peaky blinders like this.
  9. peaky blinders
    I'm not 100% on this but I'm sure I read aggressive doze takes 2 hours to kick in after phone is put in stand by
    Android450 likes this.
  10. Android450
    I wouldn't know lol
  11. Android450
    I didn't like the UI of Facebook lite, I am using messenger lite though
    Nevabackdown and Sun90 like this.
  12. Android450
    Sun90 likes this.
  13. Android450
    Marshmallow Jun 1, 2017
    Sun90 likes this.
  14. adpro
    KitKat Jun 1, 2017
    adpro , Jun 1, 2017 :
    Seems friendly is also a battery hog.
    Getting system warning for it. Had to force close on 2 occasions.
    Sun90 likes this.
  15. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 1, 2017
    Dresa91 , Jun 1, 2017 :
    Fine, no problems or draining so far :) as I said, great tips:)
    zoestar, Sun90 and Android450 like this.
  16. Rakesh MH
    Cupcake Jun 1, 2017
  17. Android450
    Android450 , Jun 1, 2017 :
    Then read the thread?
    Sun90 likes this.
  18. Android450
    How do you have notificationssetup? Do you have it optimized or unoptimized?
    Sun90 likes this.
  19. adpro
    KitKat Jun 1, 2017
    Unoptimised
    Sun90 likes this.
  20. G_Dhaval_Shah_NMTx
    Cupcake Jun 1, 2017
