423
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. _DEDSEC_
    Jelly Bean May 28, 2017
    _DEDSEC_ , May 28, 2017 :
    You must let it calibrate up too 4-5 days. Charge your phone 15-100% and it will sort it self out.
    #81
  2. Maheshkamath26
    Cupcake May 28, 2017
    Maheshkamath26 , May 28, 2017 :
    my phone is new just 4 days old! it gets overheated and are you sure this is normal?
    #82
  3. toastytoast1234
    Marshmallow May 28, 2017
    toastytoast1234 , May 28, 2017 :
    Sadly yes, it's entirely normal for people like you not to search the forum and see hundreds of posts of information and advice on this.
    #83
    j244 and gubro like this.
  4. _DEDSEC_
    Android450 The mysterious WLAN filter has been answered. This might be the only informative thread I have read in days. Great job!
    #84
    Pappl, ssagheer, Dresa91 and 4 others like this.
  5. nen3i
    Honeycomb May 28, 2017
    nen3i , May 28, 2017 :
    well let's take this step by step.
    what do you mean by overheated. what were you doing with the phone when it overheated?
    what do you mean by quick drain?
    post some screenshots with the drain and SOT.
    if you were using GPS it's normal to overheat, play intense games, it's normal to overheat and the list can continue.
    give us more details not just a simple it's draining and overheating this doesn't help
    #85
  6. F_Milind_Boruah_VjNo
    F_Milind_Boruah_VjNo , May 28, 2017 :
    OK. thanks
    #86
  7. Loveit
    KitKat May 28, 2017
    Loveit , May 28, 2017 :
    Is that face the famous "Blue Steel"? I never thought I would see it in real life again..
    Incredible.
    #87
    vasaxter likes this.
  8. F_Milind_Boruah_VjNo
    whenever I use the phone for some time it gets overheated automatically and the battery back up is not so good..it's drains from. 100% to 60 in just and hours even if I. don't use the internet
    #88
  9. nen3i
    it's normal behaviour. let it settle for a couple of weeks.
    #89
  10. varma246
    Lollipop May 28, 2017
    #90
    Android450, Dresa91 and mr_priyanshu like this.
  11. gubro
    KitKat May 28, 2017
    gubro , May 28, 2017 :
    We are advising cupcakes a few months now. Use the search.
    #91
  12. Dresa91
    User of the Year 2016 May 28, 2017
    Dresa91 , May 28, 2017 :
    I enable airplane mode over night, because I don't need any notification
    #92
  13. gubro
    KitKat May 28, 2017
    Instead of watching youtube, you should have used the search function.
    #93
  14. gubro
    KitKat May 28, 2017
    Oi! That's my line!
    #94
  15. vasaxter
    Eclair May 28, 2017
    vasaxter , May 28, 2017 :
    Charging is heat producing. High cpu load is heat producing. Heavy Wi-Fi or especially 4G usage is heat producing. Combine all of them and you can fry eggs on your phone. But you and only you will be responsible for high heat.
    #95
  16. nicktune1219
    nicktune1219 , May 28, 2017 :
    I have a 3t and I might watch YouTube videos for a half an hour, and my battery will drain to 50%, sometimes when I am not touching my phone the battery will drain, but I cannot figure out the cause. Last week, I was able to watch hours of YouTube videos from full battery to half.
    #96
  17. shekar007
    Gingerbread May 28, 2017
    #97
  18. Urny97
    #98
  19. EN_RG
    EN_RG , May 28, 2017 :
    There are so many solutions to the battery problem.. You could've solved the issue by searching in the time that u decided to make this thread
    #99
    quaddropop likes this.
  20. sahil sonii
    Froyo May 28, 2017
    shekar007 likes this.
