421
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. noynoykarl
    Eclair Jul 15, 2017
    noynoykarl , Jul 15, 2017 :
    Okayyy before somoene will pinpoint that this is a useless thread and i should have searched one. I did my research here in forums and didn't exactly found what i have.
    As the title it is an "Abnormal" drain which means i dont get this since i bought this phone. As you can see in the screen shot, the drain on phone idle is very high, in a little amount of time. And that line graph shows why. Anyone who can help me with this or have the same issue??
  2. G_ketan_shah_grQM
    Froyo Jul 15, 2017
    G_ketan_shah_grQM , Jul 15, 2017 :
    Hi,
    This could be possible coz of some application which run in background. This may cause battery drain and u cnt blame this phone for this....ideal mode also may drain some battery coz of sum apps...
    noynoykarl likes this.
  3. yawarkhalid
    Honeycomb Jul 15, 2017
    yawarkhalid , Jul 15, 2017 :
    Same thing started happening for me just last week. Neever happened before. Maybe after some app's update.
  4. G_OFFROADER_40_xJrN
    Eclair Jul 17, 2017
    G_OFFROADER_40_xJrN , Jul 17, 2017 :
    should i go for open beta .... i need better battery life
    . currently I'm on oxygen os 4.1.6 and the battery life is disastrous
    ..SOT is about 2hrs and i have almost no third party apps
  5. F_Ruchika_Nandwani_nLdl
    Cupcake Jul 17, 2017
  6. keertivaibhav
    Froyo Jul 17, 2017
    keertivaibhav , Jul 17, 2017 :
    check ur wi fi scanning settings....location settings.....bluetooth scanning....apps permissions....try to minimise them all......battery if not better yet...than go for factory reset and again perform optimization without installing any apps.....try this......SOT doesnt exactly reflects battery performance all the time.... depends upon how u are using ur android...
    Rishikesh 007 and actuallydavide like this.
  7. YeboyEJ
    Eclair Jul 17, 2017
  8. pgsk97
    Honeycomb Jul 17, 2017
    Rishikesh 007 likes this.
  9. G_OFFROADER_40_xJrN
    Eclair Jul 17, 2017
  10. F_Soumik_Majumdar_SYwr
  11. Lalithchandrasekar
    Eclair Jul 17, 2017
    Lalithchandrasekar , Jul 17, 2017 :
    in 4.1.6 I was getting nearly 4-5 hrs SOT and in open beta 10 I'm getting 5+ hrs SOT.
    it depends upon how you use your mobile based on my personal experience open beta 10 is better than official 4.1.6
  12. Rishikesh 007
  13. Singh is Kinng
    Gingerbread Jul 17, 2017
  14. rahatkhanemon
    rahatkhanemon , Jul 17, 2017 :
    i installed open beta 10 in my op3t the battery life was disappointing also i faced overheating problems when i call someone and talk like 5 mnts also when i use camera for 2 or 3 mnts the phone was heating up like a microwave oven
  15. Daasty
    Daasty , Jul 17, 2017 :
    Last beta is awesome in battery life. I was getting 3-4 sot (even worst in official) with beta 9, now 5-5:30sot in 10.. Just awesome.
  16. Harshavardhan_Khot_6
  17. mayank.hmc16
    Eclair Jul 17, 2017
    mayank.hmc16 , Jul 17, 2017 :
    I had some fuzzy gps location issues with my OnePlus 3T, so after some chats with OnePlus support, they said that they need to remotely flash my device to solve this. After flashing,
    -My gps problem still remained the unsolved
    -My SOT drastically decreased to around 1.5-2 hours with no apps installed(previously i used to get around 4-5 hours along with lots of apps)
  18. darius1988
    KitKat Jul 17, 2017
  19. Bharat_sharma_579
    Bharat_sharma_579 , Jul 17, 2017 :
    i too face same issue, about to ask for same.. So anyone suggest whixh latest beta is good with battery life ?
  20. jaybajaj1902
    Froyo Jul 17, 2017
    jaybajaj1902 , Jul 17, 2017 :
    hey was facing similar issues.
    I moved to open beta 10 on my 3T.
    no noticeable improvement in battery life.
    but the new look is refreshing... helping me not hate my 3t.
