421
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. malidan
    Marshmallow May 28, 2017
    malidan , May 28, 2017 :
    You should really post some stats so people can see what's happening on your device, but the general complaint is OS system. I've seen someone with as much as 40% drain posted on the forum.
    The clear the cache posse will be here in a moment to tell you to do just that, but the issue is down to OP and their update program.
    Throw some battery stats up and take it from there.
    varma246 and Vedant620 like this.
  2. gubro
    KitKat May 28, 2017
    gubro , May 28, 2017 :
    That's not your biggest issue. It is that you refuse to search.
  3. Android450
    Dresa91 and mr_priyanshu like this.
  4. Android450
    Android450 , May 28, 2017 :
    Thank you! @elanglois was kind enough to help me out with that :)
    elanglois and _DEDSEC_ like this.
  5. Android450
    Ultimate battery saver :D
    Dresa91 likes this.
  6. Android450
    You're welcome! I tried to make it as easy to understand as possible.
    Cher1 likes this.
  7. chetan sannotra
    Gingerbread May 28, 2017
  8. Android450
    If you're charging they won't turn off. Also some you aren't able to turn off but most of them you are.
  9. chetan sannotra
    chetan sannotra , May 28, 2017 :
    I m not charging and those r 3rd party apps
  10. Android450
    Try holding it down for a few seconds. If you have them open they won't shutdown also.
  11. chetan sannotra
    Thanks, but after reboot, they r inactive now.
    Thanks bro..
    How many processes u think we should allow in our background as a normal user?
    I had limited to 4
    Android450 likes this.
  12. Android450
    Up to you. I have it at the standard limit. I just make sure things are inactive after a charge, when I go to bed, or when I feel some heat (which isn't often)
  13. chetan sannotra
    Yes... But u should try data saver it ll do all this job I had tried it it is very useful though.... Only problem is os it takes too much battery on stock
    darius1988 likes this.
  14. Android450
    People have recommended having WiFi and data off while sleeping. I tried it last night and I saw no drain whatsoever. If you don't need any notification while sleeping it's worth a shot.
  15. chetan sannotra
    Yes but sometimes, if u have gf, u need to keep it on she might get angry if u didn't reply her because in india situation is different for few girls they can't call u but they can message u
    Tushar12333 and Android450 like this.
  16. Android450
    Yes it all just depends on what you need at least keep one of them off to minimize the amount of drain. Hopefully we get 7.1.2 soon and it has a fix.
  17. chetan sannotra
    Well everything need juice(battery) , dude, so I guess it just may provide them less n minimum the heating issue
  18. Android450
    Yes of course haha devices take battery no matter what. I just find it odd I've never encountered such drain over night with WiFi and mobile data on. ~5% every night
  19. VijayMsd
    Donut May 28, 2017
    Android450 and Dresa91 like this.
  20. Android450
    Bobbie63, Sun90 and Dresa91 like this.
