423
OP3/3T Battery and Heating tips (Nougat/Oreo/Pie)
  1. Android450
    Marshmallow May 29, 2017
    Android450 , May 29, 2017 :
    That's pretty normal as long as it's not too hot to touch. Are you using it while charging?
    Sun90 likes this.
  2. SimonRam
    Lollipop May 29, 2017
    Sun90 likes this.
  3. F_Dennis_Schröder_kNSQ
    Gingerbread May 29, 2017
    F_Dennis_Schröder_kNSQ , May 29, 2017 :
    Can anyone explain to me why my OP3 is heating up more than usual and starts to lag after some time if Google Chrome isn't deactivated?
    What does Chrome do in background that the complete device (no weak one) is slowing down for no reason?
  4. F_Dennis_Schröder_kNSQ
  5. Android450
    Sun90 likes this.
  6. Android450
    It uses up way too many resources. Maybe because of syncing with the Google account.
    Sun90 likes this.
  7. adpro
    KitKat May 29, 2017
    adpro , May 29, 2017 :
    Google is used as Android webview by default. Maybe that could be the reason. Not sure though.
    System reset from recovery will definitely help. Back up contacts and messages before doing that.
    Sun90 likes this.
  8. Funk Wizard
    Moderator Moderator May 29, 2017
    Sun90 likes this.
  9. Android450
    No need just use brave browser
    Sun90 and zoestar like this.
  10. adpro
    KitKat May 29, 2017
    Yes. Good alternative solution.
    Sun90, zoestar and Android450 like this.
  11. F_Dennis_Schröder_kNSQ
  12. Android450
    Well your bookmarks don't sync across browsers you'll need to manually add them
  13. F_Dennis_Schröder_kNSQ
    But I can't do a system reset everytime an app goes crazy.
    There must be a reason for that.
  14. Android450
    Because chrome sucks :p
    Sun90, zoestar, adpro and 1 other person like this.
  15. F_Dennis_Schröder_kNSQ
    [e]1f44c[/e]
    Ok that's a good reason.
    Now, after disabling it the play services seem to hold the device active a long time. Is that normal too?
  16. Android450
    Best to clear cache from it, or uninstall updates from it and reinstall them again
    Sun90 likes this.
  17. F_Dennis_Schröder_kNSQ
    Android450 likes this.
  18. hotleo
    Cupcake May 29, 2017
  19. VijayMsd
    Donut May 29, 2017
    VijayMsd , May 29, 2017 :
    Your tips is working for me. First time got 6.30 Hrs SOT thanks once again [e]263a[/e]️[e]263a[/e]️
    Sun90, Dresa91 and Android450 like this.
  20. Android450
    Sun90, adpro, Dresa91 and 1 other person like this.
