407
OP3/3T Battery and Heating tips (Nougat/Oreo)
  1. DrakenOne Cupcake Sep 4, 2018
    DrakenOne, Sep 4, 2018 :
    I even said that it was unusual, a phone shutting itself down after 30 sec of playing a simple game it's not okay.
    If i say that it has something wrong or different, trust me, i know what i'm talking about, it's my phone after all.
  2. rod_r47 Cupcake Oct 26, 2018
    rod_r47, Oct 26, 2018 :
    My oneplus 3 was unplugged 24 hours ago now on 57 %, Never overheats.
    My closest thing to Social Media is Strava,
    Google play has use 7%, down to connect from Garnin at 1%, since it was unplugged.
    I usually don't use utube outside the baseball season. Not a lot of other videos crop up.
  3. Scorlling Donut Oct 26, 2018
    Scorlling, Oct 26, 2018 :
    how much time u spend in your phone
  4. rod_r47 Cupcake Oct 26, 2018
  5. Pillai86 Gingerbread Oct 31, 2018
    Pillai86, Oct 31, 2018 :
    I think overheating degrades the performance of the device. Mine gets heated up a lot and its slower than the 600 series chipset phones. It simply gets heated up many times and nit heating up for intensive usage.
    No point in waiting for Android p for enhancements?
    Please help.
  6. anupritaisno1 KitKat Oct 31, 2018
    anupritaisno1, Oct 31, 2018 :
    The processor frequency is reduced if the temperature crosses a certain threshold
    There is another threshold set and if that is reached the CPU voltage is reduced to reduce the temperature
  7. Pillai86 Gingerbread Oct 31, 2018
    Wondering how to keep it cool..!
    AndreasPille likes this.
  8. Arvind_verma Cupcake Nov 1, 2018
    Arvind_verma, Nov 1, 2018 :
    Do anybody know what is oneplus dashboad, It is consuming much memory and battery after android OS and System.It's battery usage is also integrated in Android System, I don't even use dashboard widget.
  9. president99 Cupcake Nov 17, 2018
    president99, Nov 17, 2018 :
    I have a one plus 3 device. It is getting over heat using normal task. I don't use ram hungry apps. Even I don't play any games. What should I do ?
    BoianaRajaRamesh likes this.
  10. ghostofcain Lollipop Nov 17, 2018
    ghostofcain, Nov 17, 2018 :
    Read the pinned heating thread?
    B_Wrath likes this.
  11. president99 Cupcake Nov 17, 2018
    I can't understand your sentence
  12. ghostofcain Lollipop Nov 17, 2018
  13. G_Sumiet_Sahi_pOgJ Donut Nov 18, 2018
    G_Sumiet_Sahi_pOgJ, Nov 18, 2018 :
    I've flashed my phone twice in a month. but still the battery drainage is too fast..and phone heat up while using..I've not installed any app like fb.. just chrome and u tube.full charge last an hour or so. even on aeroplane the battery drains upto 10 to 15 %..and it keeps on showing notification..Google is draining your battery.i never open Google app.
    saikrishnavoonnaa likes this.
  14. JustNxck Cupcake Nov 18, 2018
  15. rohitmarines Honeycomb Nov 18, 2018
    rohitmarines, Nov 18, 2018 :
    calibrate u battery ....by fully discharging and then charging it to 100 percent in switch off mode ..repeat it twice ..I think that will solve it poblm
  16. anupritaisno1 KitKat Nov 18, 2018
    anupritaisno1, Nov 18, 2018 :
    Battery calibration is a myth
  17. G_Sumiet_Sahi_pOgJ Donut Nov 19, 2018
  18. Rajesh Kumar C P Gingerbread Nov 19, 2018
    Rajesh Kumar C P, Nov 19, 2018 :
    Disable both Google and Chrome app. Use Firefox or Edge browser. You should get a better battery backup.
  19. rohitmarines Honeycomb Nov 19, 2018
    rohitmarines, Nov 19, 2018 :
    then it's battery pblm ...replace ur battery
  20. G_Sumiet_Sahi_pOgJ Donut Nov 19, 2018
    G_Sumiet_Sahi_pOgJ, Nov 19, 2018 :
    ok. I'll try
