409
OP3/3T Battery and Heating tips (Nougat/Oreo)
  1. G_Sumiet_Sahi_pOgJ Donut Nov 19, 2018
  2. Topper_Gas Jelly Bean Nov 19, 2018
    Topper_Gas, Nov 19, 2018 :
    Surely if Chrome was the culprit it would show up on the battery stats as one of the big battery consumers, or does it sneakily use Google/Google Play Services as I can't stop the latter consuming over 10% of my battery per charge.
  3. Rajesh Kumar C P Gingerbread Nov 20, 2018
    Rajesh Kumar C P, Nov 20, 2018 :
    Just recently started using Edge browser and it is far more battery efficient than other browsers but the page loading speed of Chrome cannot be compared. Just use Edge browser for an hour compared to Chrome browser and you will notice the difference in battery drain.
  4. Daaman Mundra Cupcake Nov 23, 2018
    Daaman Mundra, Nov 23, 2018 :
    my phone is really heating up quickly! even if i use my phone for like continuous 4-5mins it becomes really hot....
    dasacom likes this.
  5. ghostofcain Lollipop Nov 23, 2018
    ghostofcain, Nov 23, 2018 :
    And after you read the heating thread?
    BTW your device has both hardware and software protection against overheating, if its overheating inspite of these then you need to stop using it and get it to a OnePlus service centre ASAP.
    Paschfire likes this.
  6. SoniaB Nougat Senior Moderator Nov 28, 2018
    SoniaB, Nov 28, 2018 :
    Thread merged. Please seek assistance here
    Dresa91 likes this.
  7. UmarSyed456 Honeycomb Nov 28, 2018
  8. chetanx Donut Dec 1, 2018
    dasacom and UmarSyed456 like this.
  9. UmarSyed456 Honeycomb Dec 1, 2018
  10. chetanx Donut Dec 3, 2018
    chetanx, Dec 3, 2018 :
    Hey, Just Uninstall Google and it will go back to oldest version. And problem solve.
  11. olivernz Cupcake Dec 3, 2018
    olivernz, Dec 3, 2018 :
    Same here. Phone sucking 1000mA+ doing next to nothing! Get the "Google is draining your battery" message. It gets really hot, never done this before. Started with 5.0.6 I think. Installed 5.0.7 no change.
    This is bound to damage the liion pack .
  12. meeevijay Cupcake Dec 3, 2018
    meeevijay, Dec 3, 2018 :
    disable Google app . problem solved
  13. olivernz Cupcake Dec 3, 2018
    Thanks. Worked. But wth? So is this a Google thing or a OnePlus thing? I don't see other brands going hot.
    And I'll need to see, what now didn't work anymore.
  14. Capta1nZap Ice Cream Sandwich Dec 4, 2018
    Capta1nZap, Dec 4, 2018 :
    After the last update I'm starting to experience similar issues, with various services draining the battery fast. I've let the phone settle with the update but I'm not seeing improvements. The dreaded wakelocks seem to be back for me :( It's either google play services or Android system that takes a huge chunk of my battery on a daily basis.
  15. Topper_Gas Jelly Bean Dec 6, 2018
    Topper_Gas, Dec 6, 2018 :
    How much in percentage terms?
  16. elanglois Lollipop Dec 7, 2018
  17. elanglois Lollipop Dec 7, 2018
    elanglois, Dec 7, 2018 :
    Android System means SERVICES that are asked for by apps. It's not your ROM or your kernel. It's your apps.
  18. G_chaitanya_allam_fWCv Cupcake Dec 14, 2018
  19. Pepsican Froyo Dec 14, 2018
    Pepsican, Dec 14, 2018 :
    Phones get hot when used. That is normal. Happens especially when recording video.
  20. ghostofcain Lollipop Dec 14, 2018
    ghostofcain, Dec 14, 2018 :
    There's a thread full of them in the pinned heating thread.
