407
OP3/3T Battery and Heating tips (Nougat/Oreo)
  1. G_Ritvik_Anand_eIhA Donut Dec 14, 2018
  2. B_Wrath Lollipop Dec 14, 2018
    B_Wrath, Dec 14, 2018 :
    You don't have to create a new thread for everything. Search and read.
  3. B_Wrath Lollipop Dec 14, 2018
  4. jzuijlek Cupcake Dec 14, 2018
    jzuijlek, Dec 14, 2018 :
    Check battery usage in system settings. Having said that the 3/3T is 2 years old and capacity will be a lot lower.
  5. Ankitbhat12345 Jelly Bean Dec 14, 2018
  6. Z1545409872580 Cupcake Dec 21, 2018
    Z1545409872580, Dec 21, 2018 :
    why would you recommend to turn on aggressive doze , both doze should be turned off.. and keep all apps optimized
  7. Paschfire Jelly Bean Dec 22, 2018
    Paschfire, Dec 22, 2018 :
    If you read the post you quoted, it doesn't recommend turning on aggressive doze aka advanced optimisation. So not sure what your point is.
  8. X1529500569718 Cupcake Jan 3, 2019
    X1529500569718, Jan 3, 2019 :
    Battery drains faster and device heats up a lot after December Security Patch. Does anyone have this problem? Please help. Thanks in advance.
  9. MrHari_theCarguy Jelly Bean Jan 3, 2019
  10. X1529500569718 Cupcake Jan 3, 2019
    I'll post the results soon. Thank you for your response.
    MrHari_theCarguy likes this.
  11. F_Kundan_Hamies_gFJq Cupcake Jan 12, 2019
  12. F_Kundan_Hamies_gFJq Cupcake Jan 12, 2019
  13. G_Shashank_Sahu_tqUm Cupcake Jan 20, 2019 at 6:07 PM
  14. Cervantes Lollipop Moderator Jan 20, 2019 at 6:14 PM
