OP3 LTE issue on Tmobile US
  1. kojaraty
    Froyo Jun 22, 2016
    kojaraty , Jun 22, 2016 :
    My OP3 keeps switching from LTE to 4G+ everytime I use data or do a speed test. This is a screen capture from my phone.
    You can notice the LTE icon in the status bar switching to 4G+
    I am on Tmobile US California. Is this normal?
    My model number is A3000
  2. inffy
    KitKat Jun 22, 2016
    inffy , Jun 22, 2016 :
    Yes that is normal. 4G+ is better than LTE
    mattylew80 likes this.
  3. kojaraty
    Froyo Jun 22, 2016
    But the speed is slow and my wife S6 do much better with the speedtest on the same network.
  4. housry23
    Ice Cream Sandwich Jun 22, 2016
    housry23 , Jun 22, 2016 :
    That is NOT normal. Make sure you have the right APN and if it's not an APN problem, call OnePlus and get a replacement.
  5. jon626
    Cupcake Jun 22, 2016
    jon626 , Jun 22, 2016 :
    I have the same issue on AT&T, but it's more of a "comes and goes" type of deal....I was having this problem while I was typing this message, but now it's resolved by itself.....not sure if it'll come back again tho
  6. nufob82
    Gingerbread Jun 22, 2016
    nufob82 , Jun 22, 2016 :
    I don't have this problem.. what APN are you on? I'm using T-Mobile LTE apn
  7. dkotoric
    dkotoric , Jun 22, 2016 :
    I have the same issues but mine goes from LTE to H to No signal at all and back to LTE and usually happens in lower signal areas but on my Nexus 6p I still have connection without any issues.
  8. daneoleary
    Froyo Jun 22, 2016
    daneoleary , Jun 22, 2016 :
    I'm having this issue, too, while using a Project Fi sim card, which should be giving me T-Mobile coverage. I don't seem to be having this issue with my AT&T sim card in the no. 2 sim card slot.
    However, I'm unable to send pictures via MMS using the Google Messenger app, which is my preferred app. I don't know if this is at all related to the T-Mobile issue I'm having, and I'm inclined to think it doesn't because the same issue occurs when trying to send via my AT&T sim card. However, if I switch over to Hangouts I can send pictures just fine.
    Also, I'm not sure how or where to access APN settings, or what to choose if/when I do. I don't think I've ever had to mess with APN settings before.
  9. prezes5
    prezes5 , Jun 22, 2016 :
    I should probably stick with my 6P/T-Mobile combo. Perfect connection. I remember OPO would sort of juggle the connection as well. I would have thought they would have it figured by their 3rd attempt at a phone.
  10. mannyb
    Cupcake Jun 23, 2016
    mannyb , Jun 23, 2016 :
    I have the exact same issue with MMS messages when I use my Project Fi SIM card in my OP3. Everything else works; data, texts, calls. But I cannot send MMS messages.
    Unlike you, however, I cannot send MMS messages at all. Not through Hangouts nor through Messenger or through any other app. It's really irking me, as I like the OP3 a lot so far, but I'm not prepared to switch to a different carrier just to use it.
  11. NaterTots
    Jelly Bean Jun 23, 2016
    NaterTots , Jun 23, 2016 :
    No problem with sending MMS for me.
    Also on Tmo with the Op3. I also see the LTE/4G+ thing quite a bit.
    It seems to happen to me when I'm on Band 12 LTE.
    Also can I disable the "VoLTE" notification every time I get onto Band 12?
    It's really annoying to see it keep coming into the notification panel.
  12. kojaraty
    Froyo Jun 23, 2016
    kojaraty , Jun 23, 2016 :
    Can you try to do a speed test and see what the LTE looks like? Until now I am not sure that I have defective device or not
  13. Xenocide23
    Best Answer
    Xenocide23 , Jun 23, 2016 :
    This is indeed normal. 4G+ indicates that you are using LTE_CA which is an advanced version of LTE that can utilize multiple LTE bands.
    runfast1986 likes this.
  14. jon626
    jon626 , Jun 23, 2016 :
    But it's super slow compared to LTE......I'm having the same issue with AT&T in the U.S.
  15. free1please
    Honeycomb Jun 30, 2016
    free1please , Jun 30, 2016 :
    I have them same problem on T Mobile usa, So slow. I have two other older android phones both with much faster download speeds. Constant band switching. It seems to be a band 12 issue. To bad as I really like the oneplus3 but have to return do to this issue.
