9
OP3: Marshmallow vs Nougat + My Opinions.
  1. Srinvias B
    Eclair Jan 5, 2017
    #41
  2. Lord_Babass
    Ice Cream Sandwich Jan 5, 2017
    Lord_Babass , Jan 5, 2017 :
    Good experience overall. Battery life is the same.
    After 4 days, i made a factory reset: maybe due to f2fs apps installation is soooo much faster !!!
    #42
  3. Jeroenepoenn
    Cupcake Jan 5, 2017
    Jeroenepoenn , Jan 5, 2017 :
    I have two problems regarding the Nougat update.
    1. It is not possible anymore for the battery percentage number to show up in the battery icon. Not via the settings menu, not via the UI tweak app called 'Percent Enabler'
    2. The earliest alarm used to show up under the clock in the lock screen. This was very handy at night for instance, to double check the alarm at a glimpse. This is now only shows up an hour before the alarm will ring in a notification.
    Are there solutions to these two problems?
    Thanks!
    #43
  4. Jeroenepoenn
    Cupcake Jan 5, 2017
    You can download a VPN app in the app store, such as 'Opera free VPN', and then connect to Canada. After that, search for a system update in the setting menu and it will pop up!
    #44
  5. PulkitViradiya
    Cupcake Jan 5, 2017
    #45
  6. Kirakichi
    Jelly Bean Jan 5, 2017
    Kirakichi , Jan 5, 2017 :
    Download a vpn, swotch to germany and search for update.
    voila!
    #46
