Network/Connectivity OP3 not connecting to 5G wifi
  1. shyamn84
    Cupcake Jan 27, 2017
    shyamn84 , Jan 27, 2017 :
    My OP3 is not detecting 5G wifi.. All other compatible devices with me connects seamlessly.. Any body else experiencing this?
    kingblue likes this.
  2. [GG]
    Jelly Bean Jan 27, 2017
    [GG] , Jan 27, 2017 :
    I believe there is already a thread about this issue. if I remember correctly, it has something to do with your router settings... if you search you will find your answer. Mine connects perfectly on both 5g and 2.4
  3. pajarito32
    Eclair Jan 27, 2017
    pajarito32 , Jan 27, 2017 :
    I connect whith 5GHz WLAN, but now, whith nougat, the max speed is 40-45Mbps, when it had Android 6, worked at 100Mbps
  4. Qazzy
    Cupcake Jan 28, 2017
    Qazzy , Jan 28, 2017 :
    In my O+3 I also have an issue with connecting to WiFi 5 GHz. When I turn WiFi ON phone "thinking" (and show ? sign on WiFi icon) for about 20-25 seconds. After that connection is established and everything running fine. Transfer rate is ~200 Mb/s.
    Before update to Nougat WiFi 5 GHz was connected immediately.
    At WiFi 2.4 GHz everything is OK.
    So if you have issue with no conbection to 5 GHz WiFj try to wait ~30 seconds.
  5. kingblue
    Froyo Jan 28, 2017
  6. Zh_kilat
    Android Q Jan 28, 2017
    Zh_kilat , Jan 28, 2017 :
    No problem here on ob11
  7. saikiran4ever
    Jelly Bean Jan 28, 2017
  8. kingblue
    Froyo Jan 28, 2017
